R50/53 Cigarette lighter not catching
Old Mar 27, 2009 | 08:46 PM
rolfiesb's Avatar
rolfiesb
another problem NAM,
my cigarette lighter/aux power is having issues.
when i stick a charger in the socket it has power, charges, and also has the light in the ring and around it; but when i stick the cigarette lighter in, it doesnt lock the button down to heat up the lighter; and if i hold it down, it doesn't heat it up at allwhat's going on!?! i also tried the rear lighter but that works perfect and catches the lighter and heats it up ( btw, does the lighter/aux ring in the rear supposed to light up?) anyways, i checked the fuse and they all seem to be there and plugged in the way theyre supposed to. please help me.
thanks AGAIN!!
Old Mar 28, 2009 | 06:36 PM
hunter99's Avatar
hunter99
The clips in the sides get bent from using cigarette lighter powered devices. Have had the same issue. Pull the fuse and you should be able to use a pair of insulated pliers to bend them back.
fridayxiii
Mar 24, 2022 04:41 PM
pglgp1292
Aug 9, 2017 12:45 PM
aldito2
Sep 30, 2015 10:44 AM
Jerome R Jr W
Sep 29, 2015 11:42 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
