R50/53 Cooling my engine
Old Mar 27, 2009 | 06:57 PM
cmartyna's Avatar
cmartyna
Cooling my engine
is it normal for my fan to stay on when my car is turned off? sometimes when the car has been on for a little while then is turned off in warm not hot weather, the fan stayes on when the car is turned off.
thanks again...
Old Mar 27, 2009 | 07:01 PM
ED955S's Avatar
ED955S
it does happen and it's a good one to cool off a bit.
Old Mar 28, 2009 | 05:21 PM
Fassbinder's Avatar
Fassbinder
You should also double check your coolant level. If it is low the fan may stay on longer than usual (coolant leaking at thermostat housing is a likely source of coolant loss)
Old May 13, 2009 | 06:22 PM
cmartyna's Avatar
cmartyna
my fan actually ended up being bad. took it to the mini shop and got it replaced and $650 later it works fine with a three year warranty
Kimolaoha
Jul 5, 2023 01:04 PM
cerenkov
Apr 24, 2018 07:47 AM
ki7hy
Aug 12, 2015 07:07 PM
Red Raven
Aug 11, 2015 04:48 AM
