R50/53 Forge alloy header tank - how do I install?
Old Mar 25, 2009 | 01:43 PM
worksdriver's Avatar
worksdriver
I just ordered a Forge Header Tank to replace the stock tank on my 2006 R53 Cooper S.
Can anyone give any tips on how to install? I believe the connections will be straightforward but I'm not sure how to go about draining the coolant out of the old tank prior to removal and the subsequent re-filling of the new tank.
Old Mar 25, 2009 | 02:00 PM
jimz68's Avatar
jimz68
I used a turkey baster to suck the coolant from the tank. (Do this with the engine COLD)
With the fluid removed it's just a simple matter of removing the 10mm nut holding the bracket then pulling up on the tank to get to the hose on the bottom.
Install new tank in reverse order. Pour your coolant back in, up to the "ledge" in the Forge tank.
Also, don't over-tighten the cap on the new tank. It can be a bear to remove.
Hope This Helps,
Jim
Old Mar 25, 2009 | 04:30 PM
worksdriver
Thanks, Jim.
Thank goodness for turkey basters. Now I just have to sneak it out of the kitchen without my wife seeing
Can't wait to get it installed
adrchn
Aug 13, 2019 02:11 AM
ebowling
90
Aug 4, 2019 09:15 AM
squawSkiBum
Oct 2, 2015 09:21 AM
