Navigation & Audio R53 aftermarket BT questions???
Old Mar 17, 2009 | 12:44 AM
KandyRedCoi's Avatar
KandyRedCoi
wondering what you r53 drivers/owners are using as an aftermarket BT adapter to work with the OEM radio and steering wheel buttons?
i plan on pairing it with an iPhone 3G
any tips and suggestions you guys can give would def be appreciated
thanx!
Old Mar 17, 2009 | 02:52 AM
scottab36's Avatar
scottab36
Posted it the wrong section. Repost in the 1st Generation MINIS section.
Old Mar 17, 2009 | 07:17 AM
Edge's Avatar
Edge
AdMINIstrator
Moved to 1st Gen Navigation & Audio.
Old Mar 17, 2009 | 10:15 AM
KandyRedCoi
oops my bad...
any suggestions?
Old Mar 17, 2009 | 10:40 AM
Edge's Avatar
Edge
AdMINIstrator
Originally Posted by KandyRedCoi
oops my bad...
any suggestions?
I'm not terribly much help on this, because I sprang for the OEM Bluetooth solution.
I would suggest searching this forum (just this one - the 1st Gen Nav & Audio) for the keyword "bluetooth". You should find some very useful threads.
The search mechanism here on NAM is really bad, but it does OK for one-word searches.
Old Mar 17, 2009 | 11:02 AM
KandyRedCoi
^if you dont mind me asking how much it cost you to run the OEM bluetooth?
if no other solution works better, then the OEM would possibly be the way to go
thanx!
Old Mar 17, 2009 | 11:10 AM
Edge's Avatar
Edge
AdMINIstrator
thanx!
Due to its price (the parts alone are ~$1000 for the full kit (ties into armrest dock)) the OEM option is really only worth even considering if you have the factory Nav, IMO.
There is a cheaper variant of the OEM Bluetooth that doesn't tie into the Nav - it's about $400 for the parts. There are also some vendors (like European Auto Source & Bimmernav) who sell the Nav-integrated version, without the armrest pieces, for about $850.
Obviously installation in all cases is separate.
Do you have the factory Nav? If not, my guess is that you'll probably be happer with one of the many aftermarket kits.
Old Mar 17, 2009 | 11:22 AM
KandyRedCoi
Originally Posted by Edge
Due to its price (the parts alone are ~$1000 for the full kit (ties into armrest dock)), the OEM option is really only worth even considering if you have the factory Nav, IMO.
no NAV on my MCS, so i guess id have to look for one of the aftermarket ones, thanx!
Old Mar 18, 2009 | 09:42 AM
yelocab's Avatar
yelocab
I installed the Parrot CK3000 kit with the wiring from MikeytheMini (www.newministuff.com). I think the total was around $300.
Easy install, works with the MFSW buttons. I had a SonyEricsson phone at first and the voice dialing was great. Then I got the iPhone 3g, whick does not have voice dialing, so I lost that.
Incoming sound quality through the speakers is perfect, Outgoing sound through the mic is not as good. It has taken some fiddling with microphone placement to get the sound quality in the "good" range. RIght now I have the mic clipped to the front edge of the headliner just to the left of the rear view mirror pointing right at me. This is the best position I've found. Still, driving down a rough freeway makes the sound quality poor.
Overall I'm satisfied with the results, when a truly better system comes out I may switch, but I'd like to stay with MikeytheMini's wiring loom if possible.
Old Mar 18, 2009 | 04:55 PM
KandyRedCoi
^sounds good...i will def look into that thanx!
Teh
Aug 22, 2022 04:37 AM
andrewjg1994
Jan 29, 2021 07:45 PM
kitty90034
Navigation and Audio
Aug 25, 2015 12:47 PM
AZN Optics
Aug 16, 2015 11:52 PM
Emnotek
Aug 13, 2015 05:47 PM
