Drivetrain Urgent help needed! Alta CAI install on Australian R56?
Ok, I know this is pretty straight forward - and it has been up to this point.
But I've encountered a big problem. Our R56's (Australian) don't have MAF plugs installed (at least mine doesn't) leaving the two hoses unable to connect???
If you look at page one of this PDF you will see an image which says UNPLUG MAF SENSOR PLUG which is attached to a plastic piece between two hoses - this is what I'm missing. http://www.outmotoring.com/images/how_to/ALT_intake_gen2.pdf
Please help! I'm stuck and can't find anything information regarding installing Alta CAI on Australian R56's?
You are right, our minis do not have a MAF. This means the Alta intake which is designed for a MAF will be too short to reach the intake pipe. You need to see if Alta have a adapter piece to suit a MAFless intake or make one up yourself. A section of alloy pipe and a couple of hose clamps should do the trick.
Thanks for the reply guys.
I have temporarily attached the hose in reverse so the longer end reaches the existing turbo inlet hose. Since they are the same diameter I have 'tucked' the inlet hose into the alta hose, whilst this works, I think there may be a small leak (unless the Turbo is supposed to sound like a very high pitched whistle).
I understand BMW have this MAF spacer as part of the JCW tuning kit, they couldn't give me a price and I'm still waiting for them to get back to me.. but I'm not holding my breath.
I can't find the part or any information on the Alta website..
I have a JCW tuning kit intake and I do not know how that is going to help. It has a plastic section that connects to the lower airbox section and the intake pipe but it bolts to the lower section, you need something that connects using a hose clamp.
I think your best option will be a section of alloy pipe or stainless steel (both could be polished and look very neat). Perhaps a trip to your local performance exhaust should be able to sort it out for you for $30 max, that is what I would do.
So it is sucking in unfiltered air, not good.
In regards to the part I am after refer to part# 13710429383 here:
RealOEM.com BMW R56 Cooper S John Cooper Works Tuningkit. Are you saying this won't be compatible with my original OEM piping (turbo inlet).
Topmini - there's a definite increase in top-end power, my initial reaction was bottom-end power has been sacrificed but after a few days my mind is changing..
It is very easy.
Go to an exhaust center, manufacturer, and ask him to cut you a small pieace of 20cm max of metal tube , for this diametre, in order to use it to connect these two pieces.
It's tucked in and clamped pretty tight, so if there was a leak I would say it would be 95% filtered air - still not acceptable.
You just need a spacer piece like this : http://www.viper-performance.co.uk/p...%20mm%20joiner
The correct outside diameter you will need the metal joiner pipe to be is 70mm
There is no doubt that the part you refer to will fit the OEM intake pipe, I just doubt the other end of it will fit the ALTA pipe. Added to that the end that inserts into the JCW airbox is not reinforced to withstand the clamping force of a hose clamp. In the JCW intake it fits into the airbox and is sealed by a O ring, the mounting is via the flange with two torx screws, no hose clamp. I think you will find the diameter of the section that inserts into the airbox is considerably smaller diameter than a ALTA intake tube.
I am happy to measure mine up so you can compare the outside diameter of the JCW connector to the inside diameter of the ALTA pipe. The other option is if you happen to be in brisbane we can meet up and use mine to see it will fix the issue.
Another problem is can you buy individual JCW compoonents without having previously bought a JCW tuning kit, I was under the impression that you can't.
The OEM turbo inlet hose on EU/AU spec cars is slightly longer to make up for the fact that we don't have a MAF sensor. It might be an ideal opportunity to upgrade to the JCW rigid turbo inlet hose and get the spacer mentioned above.
I still do not think this bit will match up suitably to a ALTA intake as the diameter will be too small. I still think the cheapest option would be a section of SS pipe, cut to suit at an exhaust workshop (they may have to reduce diameter at one end). I have found that the OEM induction pipe will fit over a piece of 3"diameter pipe, although it is a bit tight. The pipe is probably closer to 2 3/4" inside diameter. If the ALTA pipe is 3" diameter then a section of 3" SS or alloy pipe will suit nicely, it will need to be approx 6" long.
As many from australia will know, something that is perhaps US$15, by the time it is converted to AU$ and shipped here will cost more like AU$100. I could get this section of pipe from an exhaust place for less than $20, many will give you an off cut for nothing.
Totally understand what you're saying Mutley - decided to go another direction. I have sorted it out by purchasing (locally) an aluminum joiner as Coopman7 suggested - works perfect and cost around $8.00.
For future reference - any Aussie users based in Sydney wanting a fix for this, look no further than Just *** Imports at Kirrawee. They have aluminum piping, silicone hoses as well as hose clamps etc. http://justjap.com/store/home.php
Would be good if ALTA could at least mention this requirement on their website and make it clear what version of the Cooper S does NOT come with a MAF. Sucks when your 90% through and then realise something is wrong.
So glad to hear that you had it sorted out without paying the over the top BMW prices. How much difference has the intake made?
