R50/53 Basic manual driving question
Old Mar 12, 2009 | 11:01 AM
jazztronikk's Avatar
jazztronikk
Hi
I was wondering when you are driving let's say 4th gear going 40mph with you right foot pushing on gas... and you want to up shift to 5th gear... can I press down the clutch while my right foot is still pushing the gas pedal? Or am I supposed to let go of the gas pedal before pressing down on the clutch to change gear from 4th to 5th.
Old Mar 12, 2009 | 11:03 AM
SnappleLlama's Avatar
SnappleLlama
Yes, let go of the gas pedal when you shift, then slam that foot back down and get motoring!
Old Mar 12, 2009 | 11:12 AM
jazztronikk
Okay so going from 1st to 2nd gear... i kno that you have to let go of the clutch slowly as you push down the gas in order to have a smooth transition... but when i'm at a higher gear say going from 4th to 5th, you are saying I can just let go of the clutch very fast and slam on the gas?
so clutching/gasing is different for 4th to 5th than 1st to 2nd?
Old Mar 12, 2009 | 12:06 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Well, from any lower gear to any higher gear, you can operate the clutch independent of the gas. You do not have to "let go of the clutch slowly as you push down the gas" to keep it smooth.
At any rate, clutching/gassing procedure can vary greatly depending on your current gear, speed, and current driving style/mood.
A good thing to do is to ride with someone who is experienced and watch how they do it. Just remember not to ride the clutch at all - the pedal should only be depressed for a maximum of 15 seconds. Also, let the car wind down in whatever gear you're in up to a stop light, then go to neutral. This way, it won't use any gas while decelerating.
Old Mar 12, 2009 | 12:22 PM
Pinky Demon's Avatar
Pinky Demon
Sir, I recommend this site.
www.standardshift.com
Tell em' Pinky sent you, and have fun.
Old Mar 12, 2009 | 01:44 PM
saturn's Avatar
saturn
Old Mar 12, 2009 | 07:28 PM
artfulmini's Avatar
artfulmini
I'd much rather downshift!
Old Mar 12, 2009 | 07:52 PM
Pinky Demon
Not technically true. Most modern ECUs will cut fuel to the engine while coasting, plus if you need to evade, you then have to shift back.
Old Mar 12, 2009 | 07:54 PM
MrCooperS's Avatar
MrCooperS
Moderator
Going to neutral to stop is a easier way to do it, and should be done when your a beginner. When you get better, you can practice heel toe downshifting to a stop. It's pretty easy if you practice. I learned how to drive manual, left foot braking, heal toe downshifting, double clutch (although no necessary) all in one year. A lot of youtube videos helped a lot also.
This video helped a lot with my upshifting...
http://www.youtube.com/watch?v=3Upt0cxOUHE
please view all his other videos. their all VERY helpful.
Old Mar 12, 2009 | 08:21 PM
Pinky Demon
I like this guy too, plus, you can relate to what he's driving.
http://www.youtube.com/user/s0ggyrice
Old Mar 12, 2009 | 08:24 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
As do I, but it is not always necessary. In heavy traffic, for instance.
Well, in neutral, the engine uses some gas to keep it running.
If you hold the clutch in while at a light, you are putting excessive wear on the throwout bearing, not to mention the crank shaft bearings.
Old Mar 12, 2009 | 09:38 PM
MrCooperS's Avatar
MrCooperS
Moderator
That guy is actually in the forums.
Old Mar 13, 2009 | 10:12 AM
Pinky Demon
Well yeah, shift to neutral at a light. But if you are coming to a light, just coast in gear, and when you come to a stop, clutch in and throw it in neutral.
lalroma
20
Apr 2, 2022 06:19 PM
Bennyboy
Aug 18, 2015 07:28 AM
ki7hy
Aug 12, 2015 07:07 PM
pigajcw
Aug 11, 2015 02:37 PM
nomar116
Aug 10, 2015 11:24 PM
