Running wires thru firewall---where?
Old Oct 4, 2003 | 04:47 PM
MartyR's Avatar
MartyR
Anyone know of a convenient place to run 2 14ga wires through the firewall? Passenger side preferred, but either side will work. I do see a white plastic grommet by the cowl on the driver's side - could just run the wires through it and silicone seal it, but I can't get far enough under the dash to see whether I can actually run the wires TO it from inside the passenger compartment. Thanks - - -
Old Oct 4, 2003 | 04:54 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Best place to run wiring through the firewall is next to the power brake booster on the driver's side. You can gain additional room under the dash by removing the knee bolster under the steering wheel. This literally just pulls off, no tools needed.
Old Oct 4, 2003 | 05:19 PM
MartyR's Avatar
MartyR
I had removed the knee bolster, just didn't see the space. Will try tomorrow - how's Fulton? Balto was gray today
Thanks for the info...
Old Oct 4, 2003 | 05:35 PM
Greatbear's Avatar
Greatbear
It's the grommet above the clutch pedal arm, where the hydraulic line passes through. There is also a small wiring harness that passes through here as well. It is almost all the way at the top. The hydraulic line is greenish colored, the wiring is in a black convoluted tube:
Whatcha installing?
Old Oct 4, 2003 | 05:46 PM
Bisch's Avatar
Bisch
...or there is a grommet behind the glovebox. remove it to see. but first...we wanna know...
whatcha installin'?
Old Oct 4, 2003 | 06:27 PM
Greatbear's Avatar
Greatbear
There IS a grommet behind the glovebox as well, but the A/c system is more in the way at that point.
C'mon... yer among friends here... whatcha installing?
Old Oct 5, 2003 | 03:59 PM
CoopingInDC's Avatar
CoopingInDC
i ran my lights under the steering column. Punch a hole through the grommet up there, and run whatever you want through it.
whatcha installing???
Old Oct 5, 2003 | 04:39 PM
Greatbear's Avatar
Greatbear
Slightly harder to get to from the outside, but easier to access from below the dash is the big wiring grommet on the side of the brake booster towards the center of the car. A hint for extra working room from the outside is to pop out the cowl vent above it. Push the vent up from below while pressing the front edge to the back of the car and it comes right out. It's actually a much bigger grommet, and you can cross the wires over to the other side of the car by passing them across the cowling. Just make sure not to pass wiring near the wiper linkages inside the cowling.
Aw come on, whatcha installing?
Old Oct 6, 2003 | 07:14 AM
Bisch's Avatar
Bisch
Somebody better go check on Marty...he could be stuck under the dash!
Either that or it's top secret...
please.....whatcha installing?
Old Oct 6, 2003 | 01:58 PM
MartyR's Avatar
MartyR
heh heh heh
installed twin trumpet 125-dB Hella air horns. I'll post the pics this week - it's really trick. I put a little push-button switch into one of the vacant slots of the toggle panel so I can use the air horns independently of the steering wheel horn - and I can hold down the switch as long as I want the horns on (not a push-on/push-off type switch). Put the compressor right above the brake distro block in the passenger side cowl area, horns are bolted to a custom (read: rudimentarily bent and cut) aluminum bracket on the passenger side, attached to the motor mount bracket. Had some fun polishing the bracket - looks better than chrome!
bad Baltimore drivers and street-going pedestrians beware!!!!!
Old Oct 6, 2003 | 04:33 PM
CoopingInDC
HAHA,
you are the man! and, those baltimoran drivers, BOO... Enjoy marty, hopefully i had a little influence in this. If not, oh well! see you on sat.?
Danny
Old Oct 7, 2003 | 06:45 AM
MartyR's Avatar
MartyR
yessir, should be there. Hey, I read your response re: installing your goodies - still need a hand, or are you all set? see you sat for botty-hauling.
silence2-38554
98
Sep 21, 2016 02:52 PM
Super Coop
Aug 17, 2015 05:09 PM
Getrieben
Aug 15, 2015 09:09 PM
yashmack
Aug 15, 2015 03:11 PM
xraycat
Aug 12, 2015 02:36 PM
