Random stalling out/shutting off when coming to a stop
Old Feb 26, 2009 | 10:41 PM
scott48's Avatar
scott48
Randoms times when coming to a stop and shifting into neutral, the engine will just die, tach drops straight to zero. It happens more often under hard braking from higher speeds but really will do it at any random decceleration. Sometimes it revs up after stopping and going into neutral to prevent from dying but other times is doesn't and just shuts off but all the electronics are still on, so like it just kills ignition....I assuming an ecu reflash from the dealer is needed, anyone else have a similar issue, mines and '07 MCS.
Old Feb 27, 2009 | 09:22 AM
esonwood's Avatar
esonwood
are you sure this is not just your stop start function?
Old Feb 27, 2009 | 09:35 AM
scott48's Avatar
scott48
...dude the '07s don't have that
Old Feb 27, 2009 | 10:10 AM
ClubmanS's Avatar
ClubmanS
Stop/start function is not offered in US spec MINIs.
Old Feb 27, 2009 | 10:08 PM
Beeman's Avatar
Beeman
09 JCW. Come to stop in fourth or fifth, put in cluch and rpm goes to far down then to high then normal. This is worse the faster the stop. Going to have it looked at when car gets out of body shop.
Old Feb 27, 2009 | 10:32 PM
scott48's Avatar
scott48
yep, same thing with me and some times it won't rev back up to keep the engine running so just shuts off...lemme know what you find out
Old Feb 28, 2009 | 02:53 AM
esonwood's Avatar
esonwood
oops just assumed everyones was the same as mine apologies
Old Feb 28, 2009 | 03:41 AM
glangford's Avatar
glangford
i had some idle problems the first year I owned my 07 mc. Dealer never found anything. The mini engineers said fuel problem, even though I used only top tier. They sent me three bottles of mini fuel system cleaner (it may have been the bmw product). I ran a bottle through about every 3000 miles. Never had the problem again.
Another thing that can cause an idle similar to what is described is a manifold leak like from a not properly seated dip stick or oil filler cap. I had that happen once stopped and looked and sure enough when I check my oil my dip stick was sitting loose in the tube. Make sure these are seated well. I'm actutally considering an aftermarket dipstick from mini mania as it has two o-rings for sealing instead of one, and looks like it might actually be readable without rolling it on a paper towel.
In retrospect I have wondered if my first year problems were actually the dip-stick coming slightly unseated. It happened only three times on real hot days while running errands around town doing several stops, a high heat load case.
Let me know what you guys find out.
Old Feb 28, 2009 | 09:25 AM
scott48's Avatar
scott48
Mine has just be doing this recently, over the past couple months only. They found a boost leak in the boost tube right before the throttle body and replaced it, but it still does it, so don't think it could be a boost leak.
Old Mar 1, 2009 | 07:08 AM
Beeman's Avatar
Beeman
To start with i thought maybe it was part of the CA smog programing for motor.
But that dose not seem right.
Markbett
Jul 3, 2016 04:28 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
kvnadriano
Aug 10, 2015 08:48 AM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
