R50/53 What goes there?
Old Feb 18, 2009 | 10:54 PM
adrianr's Avatar
adrianr
What goes there?
I was doing tests and i decided to do the one of the dash lights (test#2) and theres a light missing
whats supposed to be there? i dont remember ever seen that light on
Old Feb 18, 2009 | 10:55 PM
ScottRiqui's Avatar
ScottRiqui
I just checked the 2005 Owner's Manual, and there's no indicator light there.
Old Feb 18, 2009 | 11:00 PM
K5Cruiser's Avatar
K5Cruiser
On my 2002 it's tire pressure on the speedometer.
ON EDIT - On my 2002 tach its the ABS light.
Old Feb 18, 2009 | 11:08 PM
ScottRiqui's Avatar
ScottRiqui
I think the tire pressure indicator is on the speedometer, not the tach. Looking at the 2002 Owner's Manual, it appears that on the non-nav cars, the second spot from the right on the tach is the ABS light, and on nav-equipped cars, that spot on the tach is unused, just like the later cars.
Old Feb 19, 2009 | 12:00 AM
itsminibtch's Avatar
itsminibtch
its def tire pressure.. i know it all too well since i got a flat a couple weeks ago!
Old Feb 19, 2009 | 12:08 AM
ScottRiqui's Avatar
ScottRiqui
That's really interesting, because I'm looking at the 2002 owner's manual right now, and it says that for non-nav cars, the tire pressure light is the second from the right in the speedometer, and for nav-equipped cars, the tire pressure light is in the digital display at the bottom of the tachometer.
If the tire pressure light in your 2002 is the second indicator from the right on the tachometer, I guess that was a change that didn't make it into the owner's manual. Regardless, in adrianr's 2005, that spot in the tach is unused.
Old Feb 19, 2009 | 12:23 AM
itsminibtch
my bad, you're totally right. i didnt really pay attention to the picture.... its late... sorry i was the opposite of help haha
Old Feb 19, 2009 | 04:16 AM
hegira's Avatar
hegira
It's very hot there, isn't it?
But that could be because you're pushin' very high RPMs......
Old Feb 19, 2009 | 06:05 AM
adrianr's Avatar
adrianr
i have crono pack so many of the lights are on the one of the center the tires seat bealt airbag etc. and the hand brake is on the other little thing
Old Feb 19, 2009 | 08:07 AM
//MZero's Avatar
//MZero
I don't have Nav or chrono...but thats where my turn signal indicator light is on my 05'
Old Feb 19, 2009 | 09:20 PM
K5Cruiser's Avatar
K5Cruiser
Yes, you're right. I was thinking about the speedometer for some reason when I posted that. Today when I was driving I looked and thought that I may have misinterpreted what was asked for in this post.
Old Feb 19, 2009 | 09:27 PM
MoxieMini's Avatar
MoxieMini
Is it not the turn signal? I'm pretty sure my 03 MC had a turn signal there.
Old Feb 19, 2009 | 09:33 PM
ScottRiqui's Avatar
ScottRiqui
Since adrianr has the Chrono pack, his turn indicators are on the speedometer, not the tachometer.
On the 2003 MINI, the turn signal was on the tachometer if you didn't have the navigation option, but it was the furthest-right indicator, not the second indicator from the right as shown in the original post.
Old Feb 20, 2009 | 06:07 AM
blkkouki's Avatar
blkkouki
i dont think the missing light should be as much of a worry compared to the fact that i think your engine bay may be on fire with a temp reading of 333.3
Old Feb 20, 2009 | 06:14 AM
ClubmanS's Avatar
ClubmanS
This is a Mexican MINI = Euro spec.
I bet the high beams indicator is above the center in the speedo, which is calibrated in Kilometers per hour.
Old Feb 20, 2009 | 08:42 AM
DixonL2's Avatar
DixonL2
Not to mention exceeding redline by some 2100 RPM?
Old Feb 20, 2009 | 03:18 PM
adrianr's Avatar
adrianr
are there 2 seatbelt warnings like one for driver and another for passanger? maybe it can be that.
This is the other side of the crono (the ones missing are the turn signal indicator took the photo when they blinked out)
there might be nothing like other people said
Old Feb 20, 2009 | 04:11 PM
ScottRiqui's Avatar
ScottRiqui
Trust me - there's nothing there. I have a 2006 with the Chrono Kit, and the second "indicator light" from the right on the tach is just a dummy.
You can tell for yourself if you look at the indicator lights in bright daylight. On all of the functional lights, you can faintly see the pattern of the display icon even with the indicator light off. On the spot you're asking about, there's nothing there - it's just a blank with no icon.
Old Feb 20, 2009 | 05:31 PM
adrianr's Avatar
adrianr
ooo
ok tyvmuch
heheh funny we both live in a city called the same but not the same
Old Feb 20, 2009 | 10:56 PM
//MZero's Avatar
//MZero
since the OP figured out his question, i dont feel bad posting this:
You should come to the autoX in Marina on Sunday
Old Feb 20, 2009 | 11:05 PM
ScottRiqui's Avatar
ScottRiqui
Ack - I wish I had known there was one this weekend before I made other plans. I had a bunch of fun the last time I went, but I let my BMWCCA membership lapse since I'm only going to be here a few more months. So, I'm not on the mailing list any more.
Kill a few cones for me, though!
Old Feb 21, 2009 | 03:41 AM
ClubmanS's Avatar
ClubmanS
The Mexican spec MINI has the same dash layout as any other Euro spec MINI. The lights will differ from US spec cars.
Old Feb 21, 2009 | 05:44 AM
ScottRiqui's Avatar
ScottRiqui
True - they differ, but not much. Except for the cruise-control and high-beam indicator being swapped, adrianr's indicator layout from his photos is the same as the U.S.-spec layout in the Owner's Manual. (I'll have to go outside and compare his layout to mine - they may in fact be totally identical and the Owner's Manual is just wrong.)
Regardless, he doesn't have a burned-out bulb, and he's not missing any indicators.
Old Feb 21, 2009 | 06:55 AM
hunter99's Avatar
hunter99
I wouldn't be surprised if that spot served several different uses between models, options, and country configurations. I was thinking this since the MINI D should have a glow plug indicator somewhere and the tach would be the appropriate place.
Even though on modern diesels it only takes a second or two for the glow plugs to warm up it is still a good idea to have an indicator for them.
Another thing pertaining to modern diesels is usually a coolant lamp. Not the engine temp but just a lamp. Most of the european vehicles I have seen with diesels have this. It basically tells you when the engine has got to a safe operating temp to be driven a little harder. Usually the owners manual states to shift shallower in the RPM band until the light goes out. Diesels do take longer to warm up.
Anyway, after all of that, just a thought.
Old Feb 21, 2009 | 09:01 AM
mwjohns's Avatar
mwjohns
So I have a 2005 Mini, and my tire pressure light just lite up last night. I found this strange because I got new Blizzaks last month. Does this light sense the pressure in my new tires.
BTW I bought my Mini last summer, and thought it was great till the first snow came, then I decided it was the worst snow car I had ever driven. Now that I got the new Blizzaks, it it the best snow car I have ever driven! On a related question, does the steering tighten up after getting snow tires? Mine sure did!
