Issues with remounting RF tires..damage
Old Oct 1, 2003 | 04:49 PM
dysert's Avatar
dysert
I purchased a new set of wheels and want to move my Goodyear Eagle 205/45r17 run flat tires. I have been told that it is very difficult to remove these tires and remount them because of the kevlar RF sidewalls. It is pretty easy to damage tires and or wheels. Anyone have experience to contribute? Thanks
Old Oct 1, 2003 | 05:04 PM
MaxaMini's Avatar
MaxaMini
I'll Piggy Back on your question as I too have runflats. They are mounted on 17 White Lights from Mini. I was thinking about getting steel rims for my snows as it is getting to be that time of year here in Connecticut.
The fact that the tires might be damaged upon remounting on the Mini Rims gives me one more reason to get extra rims.
Old Oct 2, 2003 | 06:08 AM
Alex@tirerack's Avatar
Alex@tirerack
With your zipcode I can help find an installer. Its true that unqualified techs can destroy the bead seat areas in mounting and dismounting. I allways look for people who are "goodyear EMT" certified. This means they can work on the C5 corvette - witch has much larger and trickeir runflats to mount, making Mini a walk in the park!
I do runflats every day onmounting and balacing line, we sell packages mounted and balaced with all needed hardware, so when you recive them you are good to go! Let me know.
Alex
Old Oct 2, 2003 | 03:43 PM
dysert's Avatar
dysert
Zip is 75246 Dallas
Thanks,
Pete
Old Oct 2, 2003 | 03:57 PM
SSMini's Avatar
SSMini
Im in the same boat. Can you help me find a shop that can change mine over? I live in Dover, Fl 33527. I have Pirelli run flats.
Thanks,
Old Oct 3, 2003 | 11:59 AM
Alex@tirerack
>>Zip is 75246 Dallas
>>Thanks,
>>Pete
Goodyear Dallas
Alex
Old Oct 7, 2003 | 04:09 AM
momini's Avatar
momini
>>Alex
I had a similar issue when I needed to get my runflat repaired. I used Tire Rack's installer recommendation list to find a shop near me (CT). This is a great resource, but talk to the shop first! The shop did a great job of fixing the tire, but butchered the rim. As Alex suggests find a shop on their list that has qualified technicians.
Old Oct 7, 2003 | 07:15 PM
dkstone's Avatar
dkstone
Boy am i lucky my brother works at an Audi dealership which has the latest machine to both balance and and also install runflats, so if I ever need to change tires you know where I am headed. They had to get this machine to balance the tires for the new A8 and the RS6.
Old Oct 10, 2003 | 04:59 AM
MaxaMini's Avatar
MaxaMini
Just got my car back from dealer. Run Flat went flat. They threw on a new Pirelli Performance for $325. Never called to ask me for OK. Never a mention when they called to say car was ready that there would be any charges.
No effort made to contact Pirelli. No pro rated consideration. 6500 miles.
Is this normal?
Old Oct 10, 2003 | 05:04 AM
Jerseygirl's Avatar
Jerseygirl
I just had a new Goodyear runflat put on to replace one that had picked up a screw. The Goodyear shop near my house did a fantastic job. Not a single scratch on my rim.
I spoke to them and they said they are one of the newest Goodyear shops, meaning they've got the latest equipment. There is special equipment required to work on the runflats that not all places have. My shop is apparently the only one in a 50 mile radius. I'm just happy they're close!
My advice to you would be to look for a newer shop that's probably more up to date. Good luck!
Old Oct 16, 2003 | 10:46 PM
OuzoMINI's Avatar
OuzoMINI
Was this in Mt. View, Ca? Sounds like I had the same problem but it took the dealership two days to change the tire (at firs they tried to tell me the rim was bent) and they still ended up having to send it out to another tire shop. I also got my rim back all nicked up. I'm sending this to the BAR. :evil:
Old Oct 18, 2003 | 07:48 AM
sdmidget's Avatar
sdmidget
I'm in central PA (17603) - trying to decide whether to go to a "winter set" of rims or just change tires on my 16" 5-stars.
Old Oct 18, 2003 | 02:18 PM
Bikeguy57's Avatar
Bikeguy57
Anybody know what the cost should be to swap runflats to new rims, incl mounting and balance.....Thanks
Old Oct 20, 2003 | 02:23 PM
Alex@tirerack
Average $20 a corner
Alex
Old Oct 23, 2003 | 02:08 PM
KatanaPilot's Avatar
KatanaPilot
>>Alex
Well Alex I've been thinking about buying a set of winter runflats from you to go with my spare 5-star rims. I went on tirerack.com and searched for places that could do runflats. (zip 02458)
Well, sure enough, Goodyear in Boston says they could do runflats. But listen to the price they quoted me: $72 per wheel to mount, plus $11.95 to balance! Including valve stem, $348 is significantly more than $80.....
Where did you get that $20 a corner from!? (or, if you could help me find a shop qualified to do the runflats in the Boston area for $25 a corner or so, I will order a set of runflat snows from you right away)
How much are everyone paying to have their runflats mounted?
Old Oct 24, 2003 | 01:25 PM
rrypma's Avatar
rrypma
$80 for runflats is VERY optimistic. Just this morning I called around to have new non-runflats installed on new rims. Average was approximately $100 for the corners. Prices were much higher than the prices listed on your site for the recommended installers.
Old Oct 24, 2003 | 05:47 PM
apexer's Avatar
apexer
Not talking runflats now but... in my area (Western PA) cost to mount AND balance is $7.50 per tire. Guess some advantage living in depressed area.
Old Oct 27, 2003 | 02:09 PM
Alex@tirerack
Waltham Little Foreign Car
$30 ea
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Old Oct 27, 2003 | 09:17 PM
Moorlockx's Avatar
Moorlockx
Alex's recommended place here in town charged me $17.00 to mount and balance one (a Pirelli) off the car. If someone's quoting much more the $25, you're getting hosed!
Old Oct 28, 2003 | 07:34 PM
KatanaPilot
Thanks Alex! (Link didn't work but I figured out which shop it is)
Look for my email to place an order with you sometime during the first week of Nov!
Old Oct 28, 2003 | 07:49 PM
greatgro's Avatar
greatgro
I had two runflats replaced (front ones worn at 25k miles). I just had the local gas station/shop do it - the place around the corner that we used to take all of our vehicles to get repaired at. Not only did they do an excellent job, they only charged me $48 and that's with tax and disposal fees.
Old Oct 29, 2003 | 07:56 AM
Alex@tirerack
I fixed the link, My bad!
Alex
Old Oct 29, 2003 | 08:07 AM
C4's Avatar
C4
Alex:
My new '04 MCS came equipped with Dunlop 16" RF tires. My zipcode is 33129 and would like to know of any qualified RF tire repair facilities in my area, should the need arises.
Thanks a bunch.
Old Oct 29, 2003 | 11:23 AM
Alex@tirerack
>>My zipcode is 33129 and would like to know of any qualified RF tire repair >>facilities in my area,
This will help
Alex
Casrio
Apr 20, 2021 01:52 AM
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
tylewis
Sep 6, 2015 01:07 PM
Sep 1, 2015 04:02 PM
