What size torx to remove rotors?
Old Feb 11, 2009 | 03:15 PM
jrprich's Avatar
jrprich
What size torx to remove rotors ??
04 MINI
Old Feb 11, 2009 | 03:27 PM
Capt_bj's Avatar
Capt_bj
90% sure that's a 50
only one of mine that has any wear!
Old Feb 11, 2009 | 03:32 PM
Xio2018's Avatar
Xio2018
Youre right, it is a T50, had to take mine off back in october.
miniconcarne's Avatar
miniconcarne
I'm 95% sure it's a 47.
...and after some research, consensus says 50. Then what did I use the 47 for...?
Old Feb 11, 2009 | 03:42 PM
Deviant's Avatar
Deviant
To round out the inside of the T50 bolt.
Old Feb 11, 2009 | 03:44 PM
miniconcarne
Sounds like you have done that.
Old Feb 11, 2009 | 03:46 PM
jrprich's Avatar
jrprich
Thanks to all.......I will go hunting for a T50
Jim
Old Feb 11, 2009 | 05:52 PM
mimini1's Avatar
mimini1
Actually I think 47 is 94% of 50
Old Feb 11, 2009 | 06:45 PM
not-so-rednwhitecooper
Isn't that the truth?
If you strip one, just drill it out till the head breaks off. The bolt has no purpose but to hold the rotor on while going down the assembly line.
Old Feb 22, 2009 | 07:18 AM
jrprich's Avatar
jrprich
It is a 50 Torx, just took my rotors off yesterday!
Thanks to all
Jim
Old Feb 22, 2009 | 07:21 AM
jrprich's Avatar
jrprich
A spring clip, like many US cars have, would have been a better solution
Old Feb 22, 2009 | 11:10 AM
Eric_Rowland's Avatar
Eric_Rowland
A spring clip for the rotor?
Old Sep 27, 2018 | 04:24 PM
aabcds's Avatar
aabcds
LOL! That's the funniest thing I've read on this forum so far.
Old Sep 27, 2018 | 04:43 PM
A383Wing's Avatar
A383Wing
Problem with the "spring clip" that you mention, is that most US cars have lug studs in the rotor hubs to attach the lug nuts to.......the Mini uses "lug bolts" per say.....there would be nothing to put the spring clip on to hold the rotor from falling off
Bryan
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
minipopkart
Aug 13, 2015 05:22 AM
wind715
Aug 11, 2015 07:56 AM
