R50/53 Front left speaker dead?
Old Feb 2, 2009 | 11:33 AM
jso123's Avatar
jso123
Hi
I have an 04 MCS ( 2nd owner )
Last owner upgrades head unit to Pioneer ( 25 watts ) and Polk speakers...no extra amp - yet. I've had the car about 5 months and love it.
Suddenly the front left speaker makes sporadically loud burst of static - at mostly lower frequencies. It sounds like it might be a loose connection somewhere.
Any suggestions where to start? Pull the head unit, or perhaps remove the door speaker ? I don't want to reinvent the wheel if this is a typical symptom of a blown speaker...and pulling apart the dash always makes me nervous. There are always extra parts left over...
Thanks for any suggestions
Old Feb 2, 2009 | 12:33 PM
blkkouki's Avatar
blkkouki
id pull the headunit and check the adapter, mine did that and it was driving me nuts, i took the door speaker out several times thinking that was it, and nope, the adapter was connecting right so the speaker wire was shaking lose every once in a while. reconnected the adapter and fixed the problem
Old May 12, 2009 | 08:48 AM
mister wiggles's Avatar
mister wiggles
Originally Posted by jso123
Hi
any update with your findings? did you figure out what was wrong with the speaker? I'm have the same issues myself. Is there a DIY to take apart the door or is it as simple as removing the 4 hex screws?
I'm also running aftermarket headunit.
Old May 12, 2009 | 09:16 AM
jso123's Avatar
jso123
It turns out the head unit was bad. I bought a new and better one on Craigslist.
The door comes off with a little prying after the 4 screws are removed. However getting them lined up to screw back in is another story. As long as you have the door panels off, a little sound deadening material helps a lot.
Good luck!
There is better DIY instructions on this site. It shouldn't be too hard to find.
Old May 13, 2009 | 09:49 AM
ScottSellersUNR's Avatar
ScottSellersUNR
i think my passenger front speaker is blown. What size are they in there...and just one way speakers ill assume since the tweeters are separate.
Old May 13, 2009 | 10:16 AM
jso123's Avatar
jso123
Fronts are 5.25. You might want to test some other speaker in its place first. It could be a problem with a crossover unit in the door or the head unit. Some additional info is at the link below: Good luck!
https://www.northamericanmotoring.co...nd-system.html
sevin
May 2, 2026 06:11 AM
rob&JCW
Feb 13, 2023 07:03 PM
FLYM1N1
Aug 15, 2015 11:20 AM
OutMotoring
Aug 6, 2015 09:32 AM
