Suspension Needing Help ASAP
Old Jan 23, 2009 | 09:26 AM
checkmate2006's Avatar
checkmate2006
Needing Help ASAP
Alright summarized version- The weekend before christmas driving on an icy road I slid into a curb bent my lower control arm, and tie rod end and a few other things.
Now jumping to Jan 19th I get my car back from the body shop so far it feels normal. So as I am driving I notice when I use the brakes I feel this out of balance feeling. Then as the week progresses the weather is amazing so I have my windows down I start to hear a once a rotation squeak. First thing I think what now. I looked at my invoice from the body shop and they have replaced everything except for the axle and the coilover which are fine. Just from that gives me greater reason its the wheel not the suspension components
So far I think I have narrowed it down to bent wheels because in the past I have hit a few pot holes and have seen the dents on the inner lip also the weight added to try to keep the wheel in balance and then hitting this curb may have really took that particular wheel way out of wack casing it to have a very very small wobble.
Old Jan 23, 2009 | 10:25 AM
howie289's Avatar
howie289
Quickest way to figure out if it's the wheel: swap it with one of the rears and see if the symtom moves/changes.
Old Jan 23, 2009 | 11:26 AM
checkmate2006
Theres the other problem through rotating wheels periodically I have pretty much put dents in all the inner lips from pot holes so swapping will only give the same results but in varying degrees.
Old Jan 23, 2009 | 01:29 PM
//MZero's Avatar
//MZero
well, you can take them to a tire shop and have them balance or attempt to balance them again.
You could also try to stop hitting pot holes and curbs
Old Jan 23, 2009 | 04:35 PM
UKSUV's Avatar
UKSUV
Your a COSTCO-size douche....Stop hitting things! You trying to be like me? The Mini cant drift like the BMW can...not even on ice!
Old Jan 23, 2009 | 04:39 PM
UKSUV's Avatar
UKSUV
Hey....Kal bought those silver TZ-10s like mine off of Brenden....Them ***** would look hot on your car... Wait...maybe a different color...who knows...
Old Jan 23, 2009 | 05:12 PM
Dr Obnxs's Avatar
Dr Obnxs
Quote of the day!!!!!
Originally Posted by UKSUV
COSTCO-size douche
I'm still laughing!!!!
Matt
Old Jan 23, 2009 | 06:26 PM
AutoXCooper.com's Avatar
AutoXCooper.com
does the list of parts show that they replace the wheel bearing/hub?
Old Jan 23, 2009 | 08:33 PM
UKSUV's Avatar
UKSUV
I know after I crashed the BMW....about 2 days later I had a vibration under braking and an on and off vibe at speeds. They replaced the hub bearing and it went away...
Old Jan 23, 2009 | 08:34 PM
UKSUV's Avatar
UKSUV
Matt
Hey Matt...I come up with shananigans like that all the time...where ya been?
Old Jan 23, 2009 | 08:52 PM
daemon2's Avatar
daemon2
Vibration under braking and rotational squeek sounds like it could be a warped rotor or the bearing.
Old Jan 24, 2009 | 01:37 PM
checkmate2006
The car has new
- hub/bearing assembly
- lower control arm, ball joints, and bushings
- turning knuckle
- tie rod end
its more then likely the wheel or the rotor that I have narrowed it down.
Old Jan 24, 2009 | 01:39 PM
checkmate2006
Justin thanks for hooking me up with the Psychiatric Hotline it has so far helped me out so much. I have recommended it to a few friends already. ROLMFAO
Old Jan 25, 2009 | 08:58 PM
UKSUV's Avatar
UKSUV
No prob buddy....I was gonna send you the ***** and hot dog one but I was thinking that you would prolly ralph your lunch like I did...
Old Jan 26, 2009 | 09:57 AM
Dr Obnxs's Avatar
Dr Obnxs
Gotta love this site!
you can't say ****, but you can say *****!
Matt
Old Jan 26, 2009 | 10:05 AM
checkmate2006
WTF that is a good point about the censorship stuff hahahaha. so far with the problem of the topic its either the wheel is toast or warped rotor.
Old Jan 26, 2009 | 10:09 AM
Dr Obnxs's Avatar
Dr Obnxs
Move the wheel...
move the rotor and retest. If it's just one, someone in a second car can see what's moving as they drive.
Also, you can take the wheel to a better alignement shop and have the run out and out of roundness checked. Or take the car to a shop with a dial indicator and measure the motion of the rotor, the wheel or both.
Matt
mishanja
Jun 22, 2016 09:59 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
