Drivetrain It's necessary change a new camshaft with mods?
Old Jan 13, 2009 | 11:36 AM
itonano's Avatar
itonano
Hi there,
have a question about my car, already bought many mods for my car like JCW CAI,ALTA echaust, ALTA intercooler, ALTA header, 380cc JCW inyectors, Minipowerprog soft, colder plugs...but i don't know if it's necessary to change the camshaftr for one better or with the stock one is fine, some people here told me that a new camshaft will break the engine,what should i do?
thanks
Old Jan 14, 2009 | 05:01 PM
Some Guy's Avatar
Some Guy
Nope, no need to swap out the cam unless you want even power, but I would do a pulley before that, cheaper, easier and more power than a cam.
Old Jan 14, 2009 | 05:54 PM
drsilvermini's Avatar
drsilvermini
+1 Do a pulley then if your still craving more power do a cam, I would suggest the RMW cam. I haven't installed mine yet but its supposed to give more power across the whole RPM range, rather than just the top end. Do a search and you can find some more info.
Edit: You probably wont want to install those injectors until you have a smaller pulley.
Old Jan 14, 2009 | 07:08 PM
Ryephile's Avatar
Ryephile
If anyone here on NAM said a camshaft change would break the engine, I certainly hope they go hide in the corner in shame.
Old Jan 14, 2009 | 10:59 PM
//MZero's Avatar
//MZero
You'll shoot your eye out!
Old Jan 15, 2009 | 04:36 AM
itonano's Avatar
itonano
thank you, yes i have a pulley 15%, didn't remember to mentioned before, after see the post from NAM, will go definately for the RMW cam, i saw they have also headers, cyl head, exhausts...for the cyl head i need also a good core exchange, do you recomend to change the cyl head with all that mods?
Old Jan 15, 2009 | 04:44 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Depends on what you're looking for, and how you drive your car. The head will make the biggest difference at the top end - if you track the car and spend lots of time at 5000+ RPM, you'll see a big gain from the head. The cam+header is a great combo that makes a big impact across the whole RPM range. And you need the cam and header to get the most out of the head, anyway... my recommendation is to do the RMW cam and header, then if you're still looking for more in the top end, save for the head.
Old Jan 15, 2009 | 06:02 AM
itonano's Avatar
itonano
thanks allot, that's very helpfully
thanks
Old Jan 15, 2009 | 06:16 AM
BlimeyCabrio
One word of caution - the header adds LOTS of sound to the car by replacing the very restrictive stock exhaust manifold. Whatever exhaust you have, the header will make it significantly louder. I personally like this... but some folks have been surprised by that change. The Alta exhaust is particularly LOUD with the RMW header...
Old Jan 15, 2009 | 06:41 AM
Luys's Avatar
Luys
Originally Posted by itonano
Hi there,
thanks
Who said a new camshaft will break the engine?
Old Jan 15, 2009 | 08:47 AM
itonano's Avatar
itonano
wow what sound,it is very loud, i saw it today on youtube also, that mini has the exhaust and header from RMW? i think with that sound would be a big problem od DB, and police all the time...with the Alta sportone exhaust is possible to add the RMW header? and it is necessary the 400cc inyectors from RMW? because i have the 380cc JCW
Old Jan 15, 2009 | 09:07 AM
drsilvermini
I think that was the alta exhaust in the video with an RMW header. It is possible to add the RMW to all exhausts. The 380 injectors are fine unless you getter a bigger cylinder head then you want 440cc injectors.
Old Jan 15, 2009 | 09:09 AM
BlimeyCabrio
Exactly ^ what he said.
Old Jan 15, 2009 | 09:30 AM
itonano's Avatar
itonano
oh ok, nice then, very loud if i get the RMW header...
Old Jan 16, 2009 | 01:21 PM
Thumper460's Avatar
Thumper460
zackly... now that there are more cams to choose from ( schrick/ Newman/ Cat /1320/ RMW ect..,) and the Cam is a straight forward install ( usually 2 hours or less) It will help thru the entire rpm band. then add the Header, the exhaust, and the head .. this will allow for the major cost ( the Head) as a last mod!! then the tune to finish it all up!! cool??
Just me............................
Thumper
Old Jan 17, 2009 | 08:00 AM
itonano's Avatar
itonano
yes that's for sure what i'm buying for the car, i will put all together at once
sevin
May 2, 2026 06:11 AM
Svejk
Feb 24, 2019 12:18 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
minipopkart
Aug 13, 2015 05:22 AM
