North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Drivetrain (Cooper S) (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s-16/)
-   -   Drivetrain It's necessary change a new camshaft with mods? (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s/161562-its-necessary-change-a-new-camshaft-with-mods.html)
itonano Jan 13, 2009 11:36 AM
Hi there,
have a question about my car, already bought many mods for my car like JCW CAI,ALTA echaust, ALTA intercooler, ALTA header, 380cc JCW inyectors, Minipowerprog soft, colder plugs...but i don't know if it's necessary to change the camshaftr for one better or with the stock one is fine, some people here told me that a new camshaft will break the engine,what should i do?
thanks
Some Guy Jan 14, 2009 05:01 PM
Nope, no need to swap out the cam unless you want even power, but I would do a pulley before that, cheaper, easier and more power than a cam.
drsilvermini Jan 14, 2009 05:54 PM
+1 Do a pulley then if your still craving more power do a cam, I would suggest the RMW cam. I haven't installed mine yet but its supposed to give more power across the whole RPM range, rather than just the top end. Do a search and you can find some more info.
Edit: You probably wont want to install those injectors until you have a smaller pulley.
Ryephile Jan 14, 2009 07:08 PM
If anyone here on NAM said a camshaft change would break the engine, I certainly hope they go hide in the corner in shame. :mad:
//MZero Jan 14, 2009 10:59 PM
You'll shoot your eye out!
itonano Jan 15, 2009 04:36 AM
thank you, yes i have a pulley 15%, didn't remember to mentioned before, after see the post from NAM, will go definately for the RMW cam, i saw they have also headers, cyl head, exhausts...for the cyl head i need also a good core exchange, do you recomend to change the cyl head with all that mods?
BlimeyCabrio Jan 15, 2009 04:44 AM
Depends on what you're looking for, and how you drive your car. The head will make the biggest difference at the top end - if you track the car and spend lots of time at 5000+ RPM, you'll see a big gain from the head. The cam+header is a great combo that makes a big impact across the whole RPM range. And you need the cam and header to get the most out of the head, anyway... my recommendation is to do the RMW cam and header, then if you're still looking for more in the top end, save for the head.
itonano Jan 15, 2009 06:02 AM
thanks allot, that's very helpfully
thanks
BlimeyCabrio Jan 15, 2009 06:16 AM
One word of caution - the header adds LOTS of sound to the car by replacing the very restrictive stock exhaust manifold. Whatever exhaust you have, the header will make it significantly louder. I personally like this... but some folks have been surprised by that change. The Alta exhaust is particularly LOUD with the RMW header...
Luys Jan 15, 2009 06:41 AM
Originally Posted by itonano (Post 2627063)
Hi there,
thanks
Who said a new camshaft will break the engine?
itonano Jan 15, 2009 08:47 AM
wow what sound,it is very loud, i saw it today on youtube also, that mini has the exhaust and header from RMW? i think with that sound would be a big problem od DB, and police all the time...with the Alta sportone exhaust is possible to add the RMW header? and it is necessary the 400cc inyectors from RMW? because i have the 380cc JCW
drsilvermini Jan 15, 2009 09:07 AM
I think that was the alta exhaust in the video with an RMW header. It is possible to add the RMW to all exhausts. The 380 injectors are fine unless you getter a bigger cylinder head then you want 440cc injectors.
BlimeyCabrio Jan 15, 2009 09:09 AM
Exactly ^ what he said.
itonano Jan 15, 2009 09:30 AM
oh ok, nice then, very loud if i get the RMW header...
Thumper460 Jan 16, 2009 01:21 PM
zackly... now that there are more cams to choose from ( schrick/ Newman/ Cat /1320/ RMW ect..,) and the Cam is a straight forward install ( usually 2 hours or less) It will help thru the entire rpm band. then add the Header, the exhaust, and the head .. this will allow for the major cost ( the Head) as a last mod!! then the tune to finish it all up!! cool??
Just me............................
Thumper
itonano Jan 17, 2009 08:00 AM
yes that's for sure what i'm buying for the car, i will put all together at once :)
