Suspension Wheel spacers with BC coilovers?
Old Jan 10, 2009 | 04:43 PM
JIMJMN's Avatar
JIMJMN
I am installing BC coilovers on a 03 MCS and the front wheels seem awfully close to the lower ring on the coilovers. Do I need wheel spacers and if so what is a good recommended size?
Old Jan 10, 2009 | 07:33 PM
Ryephile's Avatar
Ryephile
It all depends on your wheel width, offset, tire size and shape. There will not be a universal answer.
I'm sure some will think my recommendation isn't conservative enough, however if my tires will clear the struts without compressing two sheets of paper worth of clearance, I'm happy. I have yet to observe witness rub marks regardless of application, be it Detroit potholes or track-days.
Old Jan 10, 2009 | 08:06 PM
oxtox's Avatar
oxtox
et45, 215/45-17 rubbed on my bc coilovers. h&r 5mm spacers cleared things up nicely
Old Jan 10, 2009 | 08:28 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I'm gonna have to agree with ryephile on both points. I run with very little clearance and I regularly check for any signs of rubbing and have found nothing.
Old Jan 10, 2009 | 08:39 PM
bean's Avatar
bean
i check clearances w/ a business card. if it fits, it fits. it isn't going to get any closer.
Old Jan 11, 2009 | 03:51 AM
oxtox's Avatar
oxtox
btw, i forgot to mention that after i put on the 5mm spacers i could only get about 3 turns on the lug nuts...so i got the tsw lug nut conversion kit. if you need to do likewise make sure you know if you need a 12mm or 14mm set.
Old Jan 11, 2009 | 11:08 AM
Ryephile's Avatar
Ryephile
You also didn't mention your wheel width. Offset is only part of the backspace equation.
You bring up a very good point regarding safety using wheel spacers; you should have >6 turns of wheel bolt thread going into the hub to maintain good safety margin. With the use of wheel spacers, longer bolts or going to a stud and nut conversion [which is another way to get longer threads] are the only safe solutions.
Old Jan 11, 2009 | 11:50 AM
RedSkunk's Avatar
RedSkunk
I have 5mm spacers and the tsw stud kit w/ my BCs for giggles.
Old Jan 11, 2009 | 04:51 PM
oxtox's Avatar
oxtox
true, not all 215's are created equal...i have the dunlop direzza sport z1 star specs...specs avail here http://www.dunloptires.com/dunlop/di...00000&zipCode=
hope that helps
Old Jan 11, 2009 | 04:56 PM
Ryephile's Avatar
Ryephile
--->oxtox; you reinforce my point from post #2, tire size and shape are a big factor if spacers are needed. Some tires, like Falken RT-615's, are very narrow and round in profile for their size. Others, like the Dunlop Star Specs you have, are quite wide and square in profile for their size. They might as well be totally different "sizes", yet they may have the same numbers.
...but, and I gotta rib ya here...you still haven't mentioned your wheel width. You need both wheel width and offset to calculate backspacing.
Old Jan 11, 2009 | 05:05 PM
oxtox's Avatar
oxtox
ah sooooo.....i have the oem sidewalk wheels 7"
i was confused as the rubbing wasn't near where the tire and wheel meet
thanks, and i will try to be more precise in the future sensei.
Old Jan 19, 2009 | 11:28 PM
Q-4000's Avatar
Q-4000
if you are getting spacers USE LONGER BOLTS OR A STUD CONVERSION KIT!!! I had to use spacers when I put my Wilwood kit on DIDNT use new bolts and had a wheel fall off!!! I was lucky that I was doing about 2mph and felt it just before it came all the way off!!! destroyed my hub in the process (brakes were fine!!!)
Old Jan 20, 2009 | 11:50 AM
meb's Avatar
meb
Every spacer has a corresponding bolt length - buy new bolts!
And, spacers are not necessary on all four wheels...if track is increased on the front axle, this wider stance will help to alleviate some understeer by helping the front tires perform more work. My track setup was 15mm spacers added to 17 x 7" BBS 38mm offset up front and 5mm spacers to the same wheel in back - a 10mm difference. Today I use 5mm spacers up fron only. The difference is still quite noticable.
The only problem with 15mm spacers - aside from potential premature bearing wear - is that the front tires do stick out into the wind. I felt the difference at high speeds - 110~120mph and higher with an otherwise stock body - no aero aids or aero band aids.
Old Mar 1, 2009 | 09:06 AM
mini_macky's Avatar
mini_macky
i'm about to install my BC coils this coming week. wheel width 7.5, offset +45 with 215/40R17 GS-D3 tires. still hoping i won't need spacers...
which rubs which? the tire to the spring? wheel to the strut?
Old Mar 1, 2009 | 09:44 AM
oxtox's Avatar
oxtox
mine was tire onto strut
Old Mar 2, 2009 | 10:54 AM
mini_macky's Avatar
mini_macky
had my BC coils installed a few hours ago. happy to report that with 7.5" wide & +45 offset wheels & 215/40 GS-D3 i got about 2-3mm clearance from the strut
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
eatsleepautox
Oct 30, 2015 06:46 AM
luisfv56
Aug 22, 2015 12:42 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
ti22fjc
Aug 9, 2015 05:49 PM
