Subframe dilemma
Old Dec 25, 2008 | 12:43 PM
idickers's Avatar
idickers
Subframe dilemma
I dropped the subframe of our 2002 MCS today in preparation for changing the clutch. When I rolled the subframe out I discovered a broken rubber donut on the floor, about 3" in diameter. The second pic shows the donut on the subframe, although that's more for scale than geographic accuracy.
Anyone have any idea what this might go to in the engine compartment? It's either something that fell in the engine bay from a passing bird, or a vital component vital for full-function, national security, and world peace. I'd just like to find out where it goes...
Thanks,
Ian
Attached Thumbnails Subframe dilemma-dscn0019.jpg   Subframe dilemma-dscn0018.jpg
Old Dec 25, 2008 | 12:58 PM
bba's Avatar
bba
Looks like a broken coil spring section. Check the coils in the front struts for a missing last loop.
BB
Old Dec 25, 2008 | 01:57 PM
JAB 67's Avatar
JAB 67
Not a spring section; he already said that it is made of rubber.
Old Dec 25, 2008 | 08:56 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Is there a part number on it?
Old Dec 25, 2008 | 09:40 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
OMG You were driving without that?.....................Just kidding.
Doesn't look like a mini part. I've had a many subframes out, but never seen an oring that size. It looks too big to be an oil filter oring. That's the biggest rubber ring in a MINI. I wouldn't worry about it too much.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Dec 25, 2008 | 09:44 PM
bluesmini's Avatar
bluesmini
ask chadtoolio
Old Dec 25, 2008 | 09:45 PM
bluesmini's Avatar
bluesmini
opps, or Way.
Old Dec 26, 2008 | 04:49 AM
idickers's Avatar
idickers
Thanks for all the replies. The odd thing is there is no part # on the rubber o-ring. For a part that large it's very un-BMW. I mean un-Mini
Ian
Old Dec 26, 2008 | 05:50 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Could it have come from the jack or lift?
Old Dec 30, 2008 | 10:20 AM
MiniKJ's Avatar
MiniKJ
This is what it takes to change clutch?
Old Dec 30, 2008 | 05:56 PM
idickers's Avatar
idickers
I'm afraid so. First you have to drop the front subframe, then you can begin uncovering the transmission. Repeat after me, "I will not complain about changing the clutch in Rear Wheel Drive cars anymore". Repeat for several days...
Ian
Old Dec 30, 2008 | 08:38 PM
Vendor
I don't know if I should admire your guts for taking this on in your garage or call you crazy. That is not my favorite job, and I have a lift, and do one every 2 weeks. But to do it on the floor, no thanks. Good Luck to you.
Old Jan 29, 2009 | 10:30 PM
Usagee's Avatar
Usagee
Could it be a dustcover plate indicated within this diagram? (5, 7, or 8)
http://www.realoem.com/bmw/showparts...21&hg=31&fg=20
Old Jan 30, 2009 | 05:06 AM
IanF's Avatar
IanF
I agree... I've done it in a garage... but I have a scissor lift which makes life a whole lot easier... kudos.
FWIW, I've had a number of MINI's in various stages of parts and pieces and I've never seen an o-ring like that either... it was probably bouncing a long the road and onto your subframe and you didn't see it. I've found all sorts of odd items when I drop Moss full-length skid plates we and most of our friends have... It's definitely not one of the dust covers in the previous post.
Ooo... is that a 2002 I see in the other garage bay?
Old Jan 30, 2009 | 05:22 AM
idickers's Avatar
idickers
I think I finally identified the mystery rubber donut: it's a ring that runs around the circumference of the wheels on my AC Hydraulic jack. One wheel is missing the donut.
Good eye, that is indeed a 2002 in the other bay. The 2002 is an "M2", I put an S14 engine from an '89 M3 in about 10 years ago (http://web.mac.com/iandickerson/Ians..._Homepage.html). Great car, I'm putting in a cage so it's temporarily dis-assembled also. My wife has threatened me with a "one car on jack stands at a time" rule because the Mini and the '02 are up on jacks!
Ian
Old Jan 30, 2009 | 05:38 AM
IanF's Avatar
IanF
Ian
Very nice! I'm jealous of your garage right now... usually, I do wrenching projects in my g/f's garage (2 bays, but extra wide and deep enough to hold 4 cars in a pinch), but my own garage look more like your old one... barely enough room to open the doors...
Oh... and you just have to tell her, "but honey... there's a BIG difference between "project on jack-stands" and "repair work on jack stands"... Besides... it's January... it's not like you're going to be driving the 2002 around Rochester right now anyway...
Old Jan 30, 2009 | 07:37 AM
ClubmanS's Avatar
ClubmanS
Yep. Not many people consider what's involved on replacing the clutch on a FWD car like the MINI. The tear down is considerable and this is a 9-10 hour job. The clutch and flywheel are wear/maintenance items.
Manual transmissions are fun, but be prepared to put up with this or spend the coin to have someone do the honors for you.
I agree with Way... You have to either be brave or crazy to do this at home.
Old Jan 30, 2009 | 08:11 AM
idickers's Avatar
idickers
Actually, it's been kind of fun. Kind like a giant jig saw puzzle. I enjoy working on my cars, and feel like I really understand how the Mini goes together now. I took my time and figured out each step. Plus, I noticed a bunch of stuff that needed replacing "while I was in there" that a shop might have passed by. However, we have a second car, so this has not left me stranded while I waited for parts (although I am in a bit of domestic hot water to get the Mini back in the driving rotation!).
The biggest drawback has been the weather here in Rochester. I can bundle up against the cold, but I don't feel I have the dexterity with mechanics' gloves, so my hands have taken a beating. The sacrifices we make for our cars...
Ian
Old Jan 30, 2009 | 08:18 AM
ClubmanS's Avatar
ClubmanS
Ian, while there, check the suspension bushings. I bet those need replacing too.
I got a set of Powerflex poly bushings installed and the car is incredible.
Old Jan 30, 2009 | 09:36 AM
idickers's Avatar
idickers
That's a very good point, glad to hear you like the Powerflex pieces. I did in fact install the powerflex bushings for the control arms, the sway bar and the steering rack. I also installed the Powerflex inserts for the motor mounts and tranny mount.
While I was working on the back side of the engine I noticed that the two hard water lines that run under the exhaust manifold and feed the oil cooler were starting to bubble with rust, and the 4 hoses (2 at each end of the assembly) that feed the hard line were hard and inflexible. This was probably due to heat-cycling since the assembly is so close to the exhaust manifold; I replaced them pro-actively as it was simple to do with the subframe out of the way.
My exhaust also had rusted holes through the resonator, so I installed an Ireland Engineering cat-back system.
The "mission creep" has slowed the project, and I can't wait to finish putting everything back together this weekend to see how it drives with all the new bits.
Ian
Old Jan 30, 2009 | 11:57 AM
ClubmanS's Avatar
ClubmanS
Awesome. Looking forward to your post-repair report.
Old Jan 30, 2009 | 12:47 PM
IanF's Avatar
IanF
One other bit of BTDT experience: You may have to bleed the clutch when you're done. This requires compressing the slave cylinder with a special tool and using a pressure bleeder at 14 psi. I say "may" because having dropped the tranny twice in a MINI, the first time there was no problem and I didn't have to bleed it... second time... PITA... try to avoid moving the slave from it's normal position, which might help prevent air from sneaking in.
Oddly enough, a good thread on the subject is the TSW Cooper 6 spd conversion thread... (search).
Good luck!
buggyeye401
Oct 1, 2015 01:22 PM
buggyeye401
Sep 28, 2015 04:09 PM
bobbiemartin
Sep 1, 2015 10:46 AM
elightbo
Aug 17, 2015 01:50 PM
minipopkart
Aug 13, 2015 05:22 AM
