R56 Check Engine light - new intercooler HELP anyone
Old Dec 23, 2008 | 04:18 PM
Red Bull's Avatar
Red Bull
OK..just finished installing the new Alta intercooler...install went good and took it out for a test drive...everything was good...ran it pretty hard and when almost home the check engine light came on and I could only just about idle home...Boost tube all look good...any ideas????
Old Dec 23, 2008 | 06:52 PM
pilotart's Avatar
pilotart
First step should be to retrieve the code that made the check engine light come on.
Most Likely just a sensor that needs its connection checked.
Old Dec 23, 2008 | 08:02 PM
pillar's Avatar
pillar
id make sure nothing is leaking... make sure your clamps are on right
edit: keep us posted!
Old Dec 24, 2008 | 05:27 AM
Red Bull's Avatar
Red Bull
Yep..first thing I checked and everything is tight as can be. What happened after the install is we took it out for a ride and there is a development with roads and no homes, its where we go to play with the cars.
There is a 360 degree large circle...we did the circle at close to wide open, its a pretty big circle maybe 75' in diameter and all was good until about 3 minutes later....going to buy an OBD reader this morning.
Old Dec 24, 2008 | 09:29 AM
Red Bull's Avatar
Red Bull
Problem solved...seems like it when we were auto X'ing last night we must have been aroung the G limit and raised a wheel off the ground causing the YAW sensor to think the car rolled. Bought a OBDII and erased the problem. The DTC buttin should be on to avoid this...from what the dealer told me. Anyway problem solved.
Old Dec 24, 2008 | 12:31 PM
pilotart's Avatar
pilotart
so if the computer thinks you might have rolled, it makes you drive real slow
Old Dec 24, 2008 | 01:14 PM
Red Bull's Avatar
Red Bull
I was thinking if the Mini rolled you could still drive it???
Old Dec 24, 2008 | 05:40 PM
pilotart's Avatar
pilotart
perhaps if you can end the roll with the greasy side down
Old Dec 24, 2008 | 06:31 PM
Red Bull's Avatar
Red Bull
Lets hope I can do that if it ever really hapens....Merry Christmas
Old Dec 24, 2008 | 07:25 PM
pilotart's Avatar
pilotart
Merry Christmas and may all your Motoring be incident/accident free
You no-doubt have set a record for the mosts/quickest and highest quality MINI Mod jobs seen here.
Old Dec 25, 2008 | 04:22 AM
Red Bull's Avatar
Red Bull
Merry Christmas to you as well....and Thank You
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
M7Speed
Aug 6, 2015 01:48 PM
