Suspension Camber plates setup
Old Dec 10, 2008 | 05:04 PM
CooperWorks's Avatar
CooperWorks
Camber plates setup
Hello can anyone help me with the setup for my camber for front and rear ?
I have, 18x7.5 Wheels with 215/35/18 tires.
My car is -5 cm's lowered.
What's the best setup for hard daily drive?
Thankss
Old Dec 10, 2008 | 05:13 PM
WolfGTI's Avatar
WolfGTI
Is the car a purely street driven car?? or does it see some track time??
What kind of camber plates do you have if any?
Old Dec 10, 2008 | 05:17 PM
CooperWorks
i have the Hotchkis H-Sport with Koni coilovers.
Yes it's a purely street driven car. Here is a pic
Old Dec 10, 2008 | 10:51 PM
heyduard's Avatar
heyduard
Sharp ride!
On the street, -1.8 for the front works for me. though I have no choice with fixed camber plates. Front tire wear is even across the tread now. Stock front camber always resulted in the outside shoulders wearing away to bald at 15k miles, even with tire rotation at 5k mile intervals. rear camber is stock; no adjustable control arms, yet.
Old Dec 11, 2008 | 04:58 AM
catseye's Avatar
catseye
Great photo!
Old Dec 15, 2008 | 07:55 PM
markldriskill's Avatar
markldriskill
I am also running -1.8 in the front (my daily driver 2004 MCS) SPC adjustable camber plates, with FSDs and stock "sport" springs all around, 17" x 7.5" wheels and Kumho Ecstas at 38 lbs. all round unless I'm going to Vegas or something, in which case I add two pounds all around) and 19mm Alta rr anti-sway (set to "stiffest") and H-Sport adjustable lower control arms in the rear. 0 toe. Result has been perfect tread wear front and rear (Kumhos NEVER lasted or performed this well for me before) and handling I like. The car is not too prone to follow lines in the road, turns in well, very little roll in corners, but the ride is not harsh. Working well so far.
Old Dec 15, 2008 | 08:15 PM
silversmoke06's Avatar
silversmoke06
what Size wilwood brakes are those?
Old Dec 15, 2008 | 08:26 PM
Dr Obnxs's Avatar
Dr Obnxs
There is no "best"...
Where ever you start, keep track of driving tendancies (the cars, as well as yours) and adjust carefully from where you start. Street vs track isn't really as important as turns vs straight and what you like a car to perform like.
If this is a new world for you, find a good performance suspension/allignement place near where you live and start working with them.
Matt
Old Dec 16, 2008 | 05:02 AM
markldriskill
^+1
Dr O is right on the money in post 8. That's how I got my car where I like it.
Old Dec 16, 2008 | 07:41 AM
Dr Obnxs's Avatar
Dr Obnxs
The place I use
is always good for some education as well as some funny stories.....
There are two guys who do road racing there in Mustangs. They have very different driving styles and are very close in times. At one event, they traded cars for a session. They were both much much slower. The cars were set-up for each drivers "style" and because the styles were so different when they switched, they could barly keep up with the pack.....
in the 60s when one was in a more competitive race environment, one of the workers there was winning a lot. So the slower teams were always looking at what they were doing... so one weekend they set up thier car with a really, really asenine suspension bias (one side of the car much higher than the other) and lo-and-behold, next weekend a bunch of cars showed up with the very same screwy set up.
I got good laughs from the way the guys told the stories, but more importantly, the lesson burried in there is that there isn't a best, but there is a good compramize between how the car is driven and how it's set up. You match these two and you get a fast car that gets the most it has to give. You do a bad job matching the two, and you get a slow car that is harder to drive and doesn't last as long.
I live in hills. -2 camber up front doubled my tire life. If you do straight driving much more than I do, it will probably decrease tire life.
Matt
IQRaceworks
53
Jun 28, 2024 07:29 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
minimofo
Dec 26, 2015 12:03 PM
got_mini?
Oct 7, 2015 02:12 PM
