R56 Quad Driving Lights
Old Dec 9, 2008 | 07:36 AM
six-fingers's Avatar
six-fingers
Quad Driving Lights
In the November issue of Modern MINI the featured some guys Park Lane cooper and he had four driving lamps on the front. I've seen pictures of MINIs with rally lights before but I have never seen any thing like this guys they appeared to be the factory lamps. So does anyone know where you could find a kit for mounting these types of lamps, and if you were going to add a quad light system to your MINI would you get big rally lights or 4 stock looking lamps?
Old Dec 9, 2008 | 09:31 AM
Spice Orange JCW's Avatar
Spice Orange JCW
There is a kit about halfway down this page of this website.
http://www.vipcustomparts.com/minicooperparts.htm
Old Dec 9, 2008 | 09:48 AM
mattbren
You can also do it by mounting angle brackets to the grill using long bolts and fender washers. There's a thread in the DIY section on this. That's how the lights in my sig photo are mounted. The grill is very strong and you can put as many lights on there using this method as will fit.
Old Dec 9, 2008 | 09:58 AM
MiniFaron's Avatar
MiniFaron
From: Albuquerque, New Mexico No I dont need a Green Card
To NON-MINI Owners that would look dumb, but to a MINI owner that knows the history....That looks GREAT!!! I like it and keep us posted if you get this installed on you MINI.
Old Dec 9, 2008 | 10:20 AM
six-fingers
this is Number 2 on my list of things i wish to do to my MINI and if i ever get around to it and get the funds together. being a broke college student sucks
Old Dec 9, 2008 | 10:43 AM
bluemeanie357's Avatar
bluemeanie357
I got 2 lights and now I want 4 :)
That really does look sharp, and the rally lights aren't all that bright- especially if you didn't get Xenons.
Old Dec 9, 2008 | 10:49 AM
sequence's Avatar
sequence
4 DL's??
blatant overkill, IMO of course
Old Dec 9, 2008 | 12:13 PM
flyinlow's Avatar
flyinlow
I will be doing it to mine but the 2 outer lights will be Hella 500's with the yellow fog light lens and the 2 inner lights will be Hella 500's with the white driving lens.
Does anyone have a link to the DIY article? I looked in the DIY link but couldn't find anything in there.
Old Dec 9, 2008 | 02:41 PM
MiniFaron's Avatar
MiniFaron
This will look great when I get my 05 Jet Black S. When I find it!
Old Dec 9, 2008 | 03:17 PM
IzzyG's Avatar
IzzyG
flyinlow: I just finished setting up the bracket for the same set up as you have planned(2 outside fogs and 2 inner driving lights). The driving lights will be hooked up to brights while fogs will have their own toggle. The bracket installation was pretty straight forward but the wiring seems more involved. Gonna give it a shot tomorrow and will let you know what issues I have. Let me know if you have any questions.
Old Dec 10, 2008 | 11:19 AM
maximus96's Avatar
maximus96
can somebody point me to the post about mounting straight to the grill? i'm looking to install a pair of hella 500's. seems easiest and cheapest to mount to the grill instead of buying the bars and pulling the bumper.
Old Dec 10, 2008 | 11:53 AM
mattbren
Not sure where the thread is, but here's how I did it:
I used these angle brackets from mcmaster.com which are pre-painted black.
33125T14
(Same as 33125T143)
Strut Channel Accessory 90 Degree Angle Bracket,
2-Hole, Black-Painted Steel
In stock at $2.84 Each
I put them up against the outside of the grill with some thin sheet rubber behind them (also from mcmaster) to cushion them. Then I just used a combination of bolts, nuts, and fender washers from Home Depot to secure them to the grill. The bolt goes through the bracket, then through the grill slats and you use fender washers (these are large diameter washers and are in the specialty hardware drawers at HD) and nuts on the back side to clamp them in place.
The brackets are 1/4" steel so they're very strong, much more secure than the factory DL's.
Old Dec 10, 2008 | 12:00 PM
flyinlow's Avatar
flyinlow
Wiring's not a problem for me, I have an electrical background.
I've thought about mounting to the grille, and for the cost of the VIP setup, I will be going that route. Its $129, doesn't require removing the bumper, just the grille, which you would have to do either way. Also, they give you a template to cut the holes in your grille for the bracket. Very easy and will look good as well. http://www.vipcustomparts.com/minicooperparts.htm
Another option. Use the CARR light wing. It bolts to your license plate mount and gives you two mounts for lights
http://www.carr.com/store/carrlightwings.asp
Old Dec 10, 2008 | 12:11 PM
Big Daddy's Avatar
Big Daddy
This looks like the Wipac driving light kit sold in Britain. Here's a link....
http://www.wipac.com/uk/acatalog/Acc..._Lighting.html
Old Dec 11, 2008 | 03:52 AM
Kazy's Avatar
Kazy
33125T14
(Same as 33125T143)
Do you mind posting some pics of what this install looks likes? I'd like to see how everything fits together with this kind of install.
Old Dec 11, 2008 | 07:07 AM
mattbren
Here are a couple of snapshots. The backside of the grill just has the bolts coming through with fender washers, lock washers and nuts to clamp everything in place. The angle brackets have different length legs so they can be reversed if you have thicker lights that need to sit further from the grill. If you look close, you'll see the thin rubber sheet behind the bracket. This cushions the bracket and keeps it from rotating against the grill.
Attached Thumbnails Quad Driving Lights-driving-lights.jpg   Quad Driving Lights-bracket.jpg
Old Dec 11, 2008 | 09:53 AM
maximus96's Avatar
maximus96
Are those OEM lights that you have? They look smaller than the Hella 500's. i think the hellas are a little too big for my taste, but they are cheap...
Old Dec 11, 2008 | 10:45 AM
Xiek's Avatar
Xiek
I have had 4 PIAA's for a few years on my Cooper.. I love em, they help with the back roads. Wired them directly to the battery, and have a switch inside that I can turn them on with independantly.
Old Dec 11, 2008 | 11:39 AM
mattbren
Those are Eagle Eye brand lights from JC Whitney. They were around $30 for the pair if I remember correctly. They're not bad lights for being so cheap, however, they are NOT waterproof as advertised. Still, they've held up pretty well and I just preferred the look of chrome over the black plastic housings of the Hellas.
Old Dec 11, 2008 | 09:06 PM
MiniFaron's Avatar
MiniFaron
The lower grill on Xeiks MINI is a really cool idea!
Old Dec 12, 2008 | 03:59 PM
Scooner8's Avatar
Scooner8
Xiek,
What brand wheels are those ? Looks real sharp with your MINI.
Old Dec 12, 2008 | 05:49 PM
minimalistic's Avatar
minimalistic
Dude! I LOVE that roof ornament! Where'd you get it?
Old Dec 12, 2008 | 05:57 PM
Supercoopr's Avatar
Supercoopr
That look awesome!!!! I also like your bottom grille with the Union Jack....I was considering 4 PIAA lights also, but further down on the lower front bumper
Old Dec 12, 2008 | 07:08 PM
MiniFaron's Avatar
MiniFaron
I really like four lights in the front, but have heard people say that it could disrupt airflow. I see it a little but not that much! What do you think???
Old Dec 13, 2008 | 10:42 PM
imnothng's Avatar
imnothng
Here's my '03 with the Palo Uber kit. I didn't realize that I wouldn't be able to have my front plate on until I went to put it back on after the install. So far so good though.
