MINI not run for a month
Old Dec 6, 2008 | 01:09 PM
slhawk's Avatar
slhawk
I am going to be out of town for a month and my 2007 Mini will not be run for that entire period. Should I be worried about any gaskets or seals drying up and subsequently causing the car to develo oil leaks?
Steve Hawkins
Boulder CO
Old Dec 6, 2008 | 02:05 PM
six-fingers's Avatar
six-fingers
i let my old MINI (04' MCS) go for 3 months and it started up fine. don't know if climate plays a role, I'm in Florida.
Old Dec 6, 2008 | 02:22 PM
Crashton's Avatar
Crashton
You will be fine & so will your MINI. If I lived closer to you I'd offer to come over & exercise your MINI for ya.
Old Dec 6, 2008 | 05:30 PM
Benibiker's Avatar
Benibiker
Only thing to worry about is possibly the battery but I too have let my car sit for 6 weeks and it started right up.
Old Dec 8, 2008 | 08:18 AM
Bigshot's Avatar
Bigshot
No problems with the seals and such.....but you might want to put the battery on a trickle charge if it gets cold.
Old Dec 8, 2008 | 09:18 AM
djam43's Avatar
djam43
Lift the negative lead on the battery and everything will be fine. Dont close the bonnet as you will need to access the battery to reland the lead as you need power to open the doors.
Old Dec 8, 2008 | 03:23 PM
Crashton's Avatar
Crashton
Don't put a trickle charger on unless it is one that will shut off when the battery has a full charge. Otherwise you risk over charging your battery. At best it will boil the fluid out of the battery at worst it will burn your car down.
A battery tender that has a float mode is what you need. For the length of time you will be gone I would not worry about the battery. Pull the negative cable if you'd like.
Old Dec 8, 2008 | 04:15 PM
wandrur's Avatar
wandrur
Moderator
That's a very short period of time on a pretty new car. There shouldn't be any reason that you should worry about anything, seals or otherwise. A month sitting shouldn't drain your battery, either, even in the bitter cold, unless the battery is getting close to dead already.
Rest easy.
Old Dec 8, 2008 | 09:02 PM
PatM's Avatar
PatM
Originally Posted by wandrur
That's a very short period of time on a pretty new car. There shouldn't be any reason that you should worry about anything, seals or otherwise. A month sitting shouldn't drain your battery, either, even in the bitter cold, unless the batter is getting close to dead already.
Rest easy.
Absolutley correct. Your Mini will be peachy king. I leave my Mazda 3 for at times 3 months at a time and never do anything except check the tire pressure before firing up the car and driving off.
Regards,
Pat
iggi
18
Feb 9, 2026 01:00 AM
minicoclub
Aug 25, 2015 09:07 AM
Mini'mon
Aug 16, 2015 04:15 PM
Lt. Dan
Aug 10, 2015 12:46 PM
OutMotoring
Aug 10, 2015 12:15 PM
