R56 Help with grill badge!
Old Dec 5, 2008 | 11:29 AM
jcap287's Avatar
jcap287
School away from MINI
How do I get the grill off? lol. I read the directions, I feel like I'm going to tear it when I try. The things just don't want to budge nor do I want to break it.
Old Dec 5, 2008 | 12:33 PM
iwashmycar's Avatar
iwashmycar
subscribing... i need to know too (i think), because i want access to the lower grill from the top grill..
Old Dec 5, 2008 | 02:06 PM
dickdavid's Avatar
dickdavid
This thread might help:
https://www.northamericanmotoring.co...ill-badge.html
Old Dec 5, 2008 | 03:00 PM
maximus96's Avatar
maximus96
this thread has pictures, its really easy to take the upper grill off
https://www.northamericanmotoring.co...56s-guide.html
Old Dec 5, 2008 | 03:51 PM
3dognight's Avatar
3dognight
Or you can opt for the rear badge holder which mounts underneath the license plate.
Old Dec 5, 2008 | 03:53 PM
Sketch's Avatar
Sketch
It is actually very easy, just be sure to NOT break the push tabs on the lower half.
Old Dec 5, 2008 | 03:54 PM
jcauseyfd's Avatar
jcauseyfd
As it happens, I had to remove my grille again to install grille badge holders (got a new grille after a deer hit). I took some pictures and slapped together a DIY type guide.
Mini Cooper S upper grille removal guide
HTH!
Old Dec 5, 2008 | 06:16 PM
jcap287's Avatar
jcap287
I'll give it a go tommorrow if I have time! Thanks!
Old Dec 7, 2008 | 06:16 AM
remphoto's Avatar
remphoto
My soninlaw broke a tab trying to remove his so when I went to do mine I did something different.... I used wire and did not have to remove it at all!
Got some fairly stiff electrical wire and wrapped it around one of the screws that had been screwed in (did not use backing plate). Threaded wire through grille and then was able to get my hand behind enough to wrap it around the other screw. Sounds a little jerry-rigged but has held it securely for the past year, even in the carwash (no flames!). Easy to take off when you trade, too.
Old Dec 7, 2008 | 07:15 AM
DanF's Avatar
DanF
Actually to add grill badges you do not have to completely remove the grill. You only need to remove the top clips and reach down with your wrench. That is what I do anyways.
Old Dec 7, 2008 | 08:18 AM
iceman72's Avatar
iceman72
I have to remove mine completely because the badge holder has phillip screws that has to go in from the back. To top it off I have the factory driving lights. So now I gotta figure out how to get those off and take the grill off and the same time. Any suggestions?
Old Dec 7, 2008 | 11:00 AM
corcoranwtnet's Avatar
corcoranwtnet
Duct tape!
Old Aug 2, 2009 | 12:16 PM
ke4sfq's Avatar
ke4sfq
HTH!
Great work with this PDF guide. It really helped me figure out those bottom clips. I was squezing the wrong way!!
Kevin
Old Aug 2, 2009 | 12:47 PM
DrewN's Avatar
DrewN
One note - be very careful when uninstalling and installing the grille, especially around the bottom. There's potential there for scratching the bumper.
Old Aug 2, 2009 | 02:43 PM
ricbow's Avatar
ricbow
scratched my bumper putting grill back on
Old Aug 2, 2009 | 03:30 PM
Kimini03's Avatar
Kimini03
We put some masking tape on the front bumper before removing and installing our grill trim to help prevent scratching it. It seemed to work pretty good=no scratches!
Old Aug 2, 2009 | 06:16 PM
rwwilsonjr's Avatar
rwwilsonjr
Here's another link on grill removal with pictures:
http://www.forgemotorsport.co.uk/media/FMINTR56v2.pdf
Filmy
15
Jun 6, 2023 06:27 AM
vulkandino
Oct 31, 2015 08:29 PM
krohm
Sep 28, 2015 12:16 PM
BendersMINI
Sep 27, 2015 07:02 PM
Tylerlanger1
Sep 24, 2015 07:59 PM
