Suspension cost to install camber plates
Old Dec 4, 2008 | 08:25 PM
Myke@RPI's Avatar
Myke@RPI
How much time? Im looking to put them i and wondering the time quoted? How many hours? Its the ireland Engineering fixed camber plates...
Old Dec 5, 2008 | 03:35 AM
james f's Avatar
james f
hour at the most if they have a brain
Old Dec 5, 2008 | 08:49 AM
chilimac's Avatar
chilimac
i did this myself
for the first time on the Cooper. It took me 1 hour on the first corner and 30 minutes on the other.
Old Dec 5, 2008 | 09:01 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Takes one hour, they'll probably quote you two.
Old Dec 5, 2008 | 09:11 AM
Myke@RPI's Avatar
Myke@RPI
Thanks guys!
Old Dec 5, 2008 | 09:12 AM
Myke@RPI's Avatar
Myke@RPI
If I have slight mushrooming, what can I do to flatten it back out?
Old Dec 5, 2008 | 09:14 AM
OldRick's Avatar
OldRick
Do nothing to it, unless you like metal fatigue. Use camber plates or under-tower reinforcements to keep it from getting worse.
BTW, you will need a full alignment after installing camber plates...
Old Dec 5, 2008 | 10:38 AM
Myke@RPI's Avatar
Myke@RPI
Thanks... Yes, I was planning to run 1.75-2.0 neg camber in the rear and re-aligning everything...
Old Dec 5, 2008 | 11:09 AM
minilites's Avatar
minilites
Morning;if your in the L.A.area you might try getting hold of Danny at
Minicorsa or Steve at Steve's Auto Clinic both good places to get work
done.
Old Dec 5, 2008 | 11:22 AM
k-huevo's Avatar
k-huevo
I’ve removed tower deformation on a few MINIs, none have deformed towers again nor have they experienced any ancillary damage as a result of the manipulation. The hammer on wood method is practiced by the majority of the MINI dealership service departments also; a photo of the procedure can be found in post #6 here http://www.mini2.com/forum/faults-fi...shrooming.html . Drivers are usually more cautious and aware of road hazards and irregularities after repairing damage, which may be the reason why deformation seldom returns.
A how-to for removing the front struts and replacing the guide supports (yours would be camber plates) can be seen here https://www.northamericanmotoring.co...ll-how-to.html . Post #5 here https://www.northamericanmotoring.co...in-so-cal.html provides several resources if you want to price shop.
Wait until 50 or so miles are on the vehicle after IE fixed plate installation before having the alignment. The bearing carrier bushing will collapse a little affecting toe to a slight degree.
Old Dec 5, 2008 | 11:47 AM
Myke@RPI's Avatar
Myke@RPI
Thank you! great info and advice!
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
