Question about wiring, programming VTEC?
Old Nov 23, 2008 | 06:33 PM
Jemo's Avatar
Jemo
I'm leaning strongly toward doing the B16 conversion and the kits seem to make it very doable BUT I never read much about how these cars are wired. I know superfast sells a harness but is that the only option?
I've read that honda engine harnesses have to connect through the dash harness? What if you want to use aftermarket gauges (e.g. Autometer)?
Has anyone used the superfast harness? Has anyone just taken their car minus wiring to a Hondata dealer and had them reflash the ECU and use the donor engine's harness?
I've found a universal harness to put a K-series in a non-Honda chassis but nothing for D or B series. Is there a vendor for B-series harnesses?
Jeff
Old Nov 23, 2008 | 06:47 PM
meno's Avatar
meno
Don't know but you might also post at 16vminiclub.com also if you already have not.
Old Nov 23, 2008 | 08:11 PM
elprofe's Avatar
elprofe
engine harness pretty much stays the same....the rest must be shorten ran with bare essentials.....most honda tuners can do such task.
Autometer is no prob. as long as you get electronic gauges.
I had two fuse boxes on mine.....one for the mini side and one for the honda stuff.
Isolating both allowed to know where to look when lights did not work for example.
Getrieben
Sep 21, 2023 03:31 PM
TREX
Nov 2, 2019 07:31 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
Getrieben
Aug 15, 2015 09:09 PM
