Drivetrain BRISK spark plugs - first impressions
Old Nov 16, 2008 | 05:34 PM
jimz68's Avatar
jimz68
Just replaced a set of 5K old NGK Iridiums with the Brisk Racing Silver Plugs. (single electrode, DR12S)
First off, they MUST be re-gapped as they come out of the box at about .015
I gapped them to .028
First thing I noticed was a faster cold start-up. The high speed miss and hesitation I had with the NGK's is gone. (Even when new, I had a miss with the NGK's)
So, they did what I had hoped they would do so I'm a happy camper!
Jim
Old Nov 16, 2008 | 05:45 PM
Longboard Mini's Avatar
Longboard Mini
I have been running them for some time now. They are awesome plugs and also fixed a miss I had up top when I ran NGK's.
Glad to see more people running them .
Longboard
Old Nov 16, 2008 | 05:59 PM
#20Works4me's Avatar
#20Works4me
Jan threw in a set for me on my JCW when I got his tune done in Seattle. He really likes them so that's good enough for me
After the initial tune my gain was approx 9hp, then a change out of my stock JCW plugs with only 10K but had been running lean for that mileage, in go the Brisks and some more of Jan's tweaking magic and yet another 9hp!
Old Nov 16, 2008 | 09:34 PM
Ryephile's Avatar
Ryephile
I also gave Brisk plugs a try, but didn't want to comment on them until I had some solid before/after seat time. Of the two track days I did this autumn, the first was with my usual NGK BKR8EIX. The NGK's have significantly better throttle response than the stock plugs, but with their aggressively cold heat range, they offered a bit of a chunky and sluggish cold-engine response.
I installed a set of Brisk DR12YS, which are the equivalent heat range. Like Jim found, out of the box their gapping was horrid. I gapped them to 0.030", because that sounded reasonable at the moment. The results were clear upon first start-up. Smoother revving during cold operation, and even crisper and quicker throttle response at all times. On the track, however, is where these expensive plugs really surprised me. I was able to very smoothly modulate the throttle on corner exit, something I always found a difficult operation with the Tritec engine with the stock bypass valve. Somehow these plugs smoothed out that behavior and allowed me to focus on driving and not wrestling with the engines old quirks.
Two thumbs up from me. They surely suprised me with their clear effectiveness.
Cheers,
Ryan
Old Nov 16, 2008 | 09:35 PM
MrCooperS's Avatar
MrCooperS
Moderator
What's the make and model? I've been searching for some good spark plugs... are they all universal or is there a size to them? (I'm not very good with cars, but I like to buy the parts and have someone install them for me)
Old Nov 16, 2008 | 10:00 PM
MINICHEF's Avatar
MINICHEF
recently installed a set of the "lamobo" plugs not possible to re gap, much improvement over NGK.
for proper application PM Jan at RMW or go to brisk racing.com and search or ask.
I will stick with brisk from now on
Old Nov 17, 2008 | 04:45 AM
pappasp's Avatar
pappasp
which gap is the proper?i'm waiting for a reply from brisk racing but is there a list or something where i can choose a gap for my moded car!?
Old Nov 17, 2008 | 05:48 AM
AutoXCooper.com's Avatar
AutoXCooper.com
You can find more info about Brisk Plugs here
Old Nov 17, 2008 | 12:00 PM
#Dragon#'s Avatar
#Dragon#
so if your fitting the plugs to a stock head on a cooper s what is the correct gap to set them. when i spoke to ken at alta he said that you could fit them straight out of the box.
Old Nov 17, 2008 | 12:13 PM
MidniteCoop's Avatar
MidniteCoop
I picked mine up from alta, haven't installed them yet.
I was wondering about the gap as well although I to was told by Ken that they were gapped correctly out of the box.
Old Nov 17, 2008 | 03:10 PM
jimz68's Avatar
jimz68
I have never, ever screwed a spark plug into any car I've owned without checking the gap. Like I said, the Brisk plugs came out of the box at around .015. One was actually almost totally closed. I also noticed that of the four plugs, only one had a protective plastic cap over the electrode end. (I got mine from Alta, also)
Another thing, make sure the connectors at the top end of the plug are screwed on tight. Mine were all loose.
Jim
Old Nov 17, 2008 | 05:47 PM
minsane's Avatar
minsane
Hello everyone:
I just installed the 4 prong Brisk plugs model DOR14LGS-T after 70k miles on the orginal plugs. Car seems to accelerate smoother. I have a 15% pulley, CIA, and Invidia catback.
Does anyone else have experience or actal numbers with this type of Brisk Plug?
Old Nov 17, 2008 | 06:00 PM
#20Works4me
I'm pretty sure that's the one Jan threw in my car see post # 3
Old Nov 17, 2008 | 06:07 PM
Revolution Mini Works's Avatar
the 4 prongs don't need gapped but every one I have checked of the DR-12s are not gapped properly
Old Nov 17, 2008 | 06:11 PM
minsane's Avatar
minsane
Wow! Hey Jan, are you seeing those kind of gains from just changing out the original to the Brisk 4 prong?
Old Nov 17, 2008 | 06:18 PM
I'm sure if the plugs are the problem you will see gains
Old Nov 17, 2008 | 08:09 PM
MrCooperS's Avatar
MrCooperS
Moderator
What are gaps? How do you fix it? If I order the "4 prongs" I just screw them on and call it a day?
Old Nov 17, 2008 | 08:21 PM
no gapping on the 4prong
Old Nov 17, 2008 | 08:22 PM
MrCooperS's Avatar
MrCooperS
Moderator
well if jan says their good. I'm sold. where can I send my money to for these plugs.
Old Nov 17, 2008 | 08:56 PM
batrugger's Avatar
batrugger
Wow, great find Brian and Jan. I love how all of these vendors are now carrying these plugs. Kind of like the Cross coilovers. These worked so well in the MINI I am going to get a set for the Jetta
Old Nov 17, 2008 | 08:59 PM
MrCooperS's Avatar
MrCooperS
Moderator
Soon, I'm going to have a 17% pulley, one-ball, and Alta intake. Which plug (4 prong) should I buy? Anyone got a link? I'm going to buy them and have my buddy install them.
Old Nov 18, 2008 | 06:01 AM
AutoXCooper.com
For Cooper's and Stock Cooper S Models w/std. S/C Pulley use BRSK-DR14S
For Cooper S Model’s w/15% or larger S/C Pulley Upgrade (or JCW Cars) use BRSK-DR12S
https://www.northamericanmotoring.co...uct/346/cat/27
Last edited by AutoXCooper.com; Nov 24, 2008 at 01:51 PM. Reason: updated 11-24-08 due to new data from Alta
Old Nov 18, 2008 | 06:37 AM
skillet's Avatar
skillet
I've got the Lambo style as well. Bought mine used from PGT. Car definitely runs smoother Can't remember the part number, just that it had GS-T at the end of it
Old Nov 18, 2008 | 07:00 AM
davisflyer's Avatar
davisflyer
I may need to get a set as well.
Has anyone tried these pulse plugs? : http://www.pulstar.com/
Old Nov 18, 2008 | 07:23 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Id stick with the Brisk. PM me if you want.
