Drivetrain BRISK spark plugs - first impressions
Old Dec 24, 2008 | 12:13 PM
  #76
muggy's Avatar
muggy
I got my DR12S from ALTA, I'm happy with the performance coming from stock plugs on a 15%.
There is an improvement in smoothness, engine idle, and startup. My stock plugs had less than 30k on them, although the change in performance could also be since I moved to colder plugs.
Old Dec 24, 2008 | 12:57 PM
  #77
BlimeyCabrio's Avatar
BlimeyCabrio
I installed my 14LGS plugs from Jan a week or so ago... my Bypass Valve is dying, so hard to tell what the plugs are doing... but I'm betting once the BPV is replaced, the car is gonna be screamin again.
Old Jan 2, 2009 | 07:01 PM
  #78
palomita's Avatar
palomita
I have a completely stocked 05 MCS. I'm looking to upgrade starting with the plugs...Should i use the DR-14s? While I'm at it what will be a good set of wires for that plug?
Old Jan 3, 2009 | 02:26 PM
  #79
Revolution Mini Works's Avatar
use the factory wires they are better than what's out there
No real need for colder plugs unless you go to a reduction pulley
Old Jan 3, 2009 | 10:47 PM
  #80
silversmoke06's Avatar
silversmoke06
I need a set im running slightly rough up top. Course injectors wouldent hurt either....
Old Jan 4, 2009 | 01:46 AM
  #81
user 7082082's Avatar
user 7082082
I have a set that I will sell that have been on the car but are still pretty new. LMK if you want them by pming me.
Old Jan 7, 2009 | 09:31 PM
  #82
yellowbritishrocket's Avatar
yellowbritishrocket
i have joing the Brisk fanboi club...just picked up a set of 14LGS plugs from jan today and swapped in a stock set of wires tonight and wow what a difference...engine is much quieter and much smoother!
Old Jan 7, 2009 | 09:37 PM
  #83
glad they worked out
Old Jan 7, 2009 | 10:21 PM
  #84
MrCooperS's Avatar
MrCooperS
Moderator
are the 14LGS more expensive?
Old Jan 13, 2009 | 12:28 PM
  #85
fentos's Avatar
fentos
Figured I would reply to this thread as well since I installed my first set of Brisk plugs late last week.
Plugs I took out were NGK's and had around 40k on them. I had developed a slight miss under load on occasions and our gas mileage was in decline. I figured it was time for a replacement.
Installed IE plug wires from AXC and it fixed the miss that was occurring. While I was installing the new plugs my coil pack had some corrosion on the prongs, so cleaned that as well and started shopping for a new one. Drove with the wires for a few days and the car was considerably smoother. Once my DR12S came in (they were backordered), I installed those as well as an MSD Coil Pack (I know the stock was fine, but got a good deal on it). With all three pieces on and installed the car starts easier, idles great, runs much smoother, and our gas mileage has taken a huge upward turn. I did have to gap the plugs, as most of you mentioned.
Old Jan 21, 2009 | 01:41 PM
  #86
hockeyman's Avatar
hockeyman
Auto, what should the gap be? .28? I have cat back, CAI, 15%
Old Jan 21, 2009 | 02:58 PM
  #87
AutoXCooper.com's Avatar
AutoXCooper.com
Yes .028 is the most common gap.
Old Jan 21, 2009 | 02:59 PM
  #88
hockeyman's Avatar
hockeyman
Thanks, I am installing along MSD coil tonight!
Old Jan 23, 2009 | 09:56 AM
  #89
CoMo R53's Avatar
CoMo R53
Honestly I'm surprised anyone running forced induction even bothers with the NGK Irridiums. I used them on my S70 at one point (T5 2.3l 5spd car, boost cranked to about 17lbs. Car created about 300ftlbs to the front tires. Much fun for a daily) and they started breaking up almost immediately. Checked the gap, went smaller thinking blowout, and still sucked. Wires, coil, rotor and cap were all new and such. Went back to the Bosch Coppers the cars come with, and it ran perfectly.
So yeah, Irridiums... they be junk.
Old Jan 23, 2009 | 08:26 PM
  #90
sprp85's Avatar
sprp85
NGK BKR7Es (copper) are very well known among the boosted car owners.. I dont know about iridiums, anyways,! back to the topic of BRISK plugs!
Old Feb 17, 2009 | 11:46 PM
  #91
mkskchun85's Avatar
mkskchun85
Any issues with brisk?
Since it's been awhile since you all put the brisk plugs in....has anyone had any issues with the plugs? Are they better/worse than the iridiums? Are there any negatives with the plugs? I'm hopefully going to be installing my helix 15% pulley, and ssk this weekend. So far i've got a cai, and exhaust, everything else is stock.
Thanks for the help...
PS: Jan, any chance of coming out to Hawaii soon? (offer applies to fellow namer's)
Old Feb 18, 2009 | 08:14 AM
  #92
jm6001's Avatar
jm6001
I have the DR12S right now and I installed these plugs with a .028 plug gap and now my idle its definaitly off, it feels like a i have a cam in the car now! I switched from my NGK Iridiums because up high in the RPMs the motor would miss quite a bit, now with the silver's it doesnt miss anymore but the idle is all whacked out... any ideas why?
Old Feb 18, 2009 | 08:49 AM
  #93
DanSeals's Avatar
DanSeals
Have to throw in my 2 cents here. Installed some DR12S on my 04 MCS with 15% pulley and CAI and the miss/hesitation I had at part throttle acceleration is totally gone. Gapped them at .030
Old Feb 18, 2009 | 12:14 PM
  #94
hockeyman's Avatar
hockeyman
I have had great success with mine as well. With all the normal mods too.
I am being tuned and dyno'd this Friday. Will update then
Old Feb 18, 2009 | 03:16 PM
  #95
MrCooperS's Avatar
MrCooperS
Moderator
"Hello Jan,
I'm in the market right now looking for some plugs. I have no mods as of now, but will soon have a Alta CAI, 17% Pulley with a new belt, and a one-ball exhaust to start with. After much research from reading your threads, I believe the plugs I should get are the BRSK-DR12S.
But then I hear something about a "14LGS"
Which one is more suited for my MINI?"
"the ones you want are the 14LGS for your mods
the DR12s are for cars with heads etc" - Jan
Old Feb 18, 2009 | 03:51 PM
  #96
Originally Posted by MrCooperS
"Hello Jan,
yes, you need the 14LGS and we have them in stock
this is the 4 prong plug
Old Feb 18, 2009 | 04:01 PM
  #97
minipooper02's Avatar
minipooper02
How often should a mini's spark plugs be changed?
If they are changed to the brisk plugs, does the mini need a tune after install?
Old Feb 18, 2009 | 04:13 PM
  #98
no on the tune
as for changing them, the more modded the car the more often you will have to change them. I always change mine along with my oil way more often than necessary. Old habits die hard
Old Feb 18, 2009 | 05:18 PM
  #99
k_h_d's Avatar
k_h_d
Well sh$%... I just ordered the Brisk DR12 after sifting through these threads and on the recomendations on Alta's site (who I ordered from). Am I Making a mistake putting the DR12's in Jan? It sounds like there are a lot of happy people with them.
Old Feb 18, 2009 | 05:36 PM
  #100
MrCooperS's Avatar
MrCooperS
Moderator
Yeah, I found a mixed amount of answers to which plugs I should use so I PM'ed Jan directly and found out which ones I need.
