R56 Valentine 1 mount
Old Nov 16, 2008 | 01:36 PM
Performance Angst's Avatar
Performance Angst
Valentine 1 mount
Does anyone know where to purchase an Under the Mirror mount for the V1? The only one I can find is for the Bel/Escort.
Old Nov 16, 2008 | 02:55 PM
BlimeyCabrio's Avatar
BlimeyCabrio
I'm assuming you're talking about these?
http://www.countryjoycrafts.com/Conn...arDetector.htm
Have you contacted them to ask if they'll make you a MINI-style one for the V1?
Old Nov 16, 2008 | 03:22 PM
NYMCS's Avatar
NYMCS
I have the visor mount for my C6 Corvette and I bought it from www.greatlakestrophies.com . They also make a mount for the mirror. Its a simple little gadget but it serves the purpose. Im looking for one also and Ill give them a call this week to see if they make them for the Mini or see if they will. If enough people hound them they might make em.
Old Nov 18, 2008 | 04:22 PM
Performance Angst
That's somewhat ironic; I also purchased a mount from them for my C5. Please let me know if they can/will make one for the MINI.
Old Nov 18, 2008 | 04:25 PM
Performance Angst
Yes, I have contacted them regarding a mount to the V1. They stopped selling it due to installation problems. If I can't find anything else; I'll purchase the one for the Escort from them and fabricate a piece that will accept the V1 and bolt it to the bottom of their mount.
Old Nov 18, 2008 | 04:37 PM
Performance Angst
After looking over their website; it appears a slightly modified version of this mount may work by attaching to the back of the MINI mirror.
http://69.89.25.185/~trexsoft/t-rexs...irrorMount.pdf
Old Nov 18, 2008 | 06:30 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
I placed the V1 right beside (left of) the rearview mirror. Fits perfectly well right under the headliner, and plenty of room for mirror movement if needed.
Old Nov 19, 2008 | 08:17 AM
jluckyfish's Avatar
jluckyfish
Too bad they don't work for photo radar...that's all we have here, and its a cash cow!
Old Nov 19, 2008 | 03:25 PM
Performance Angst
I have not tested this but my fear would be that mounting it so high inside the car would tend to hinder signals from the rear.
Old Nov 19, 2008 | 04:09 PM
RaceTripper's Avatar
RaceTripper
I have mine mounted that way as well. Works perfectly and receives signals front and back with no problem.
I am still looking for a way to not use the windshield mount. I just did that for my Garmin Nuvi using the gauge mount bracket and Nuvi extension from Craven Speed.
Old Nov 19, 2008 | 04:37 PM
Eric (Plug Guy)
No problem at all. As long as from the box you have clear lines front/rear, you're good to go. And don't place it in a tint line up front if you can avoid it, that diminished forward values significantly. So far, I'm happy.
The other thing to remember is this: if you are pulled over, and it's a judgement call, and the cop sees your V1 down low and visible, trust me, you're toast.
Old Nov 19, 2008 | 05:41 PM
BlimeyCabrio
Many, Many MINI owners (including me) use the high mount over the rearview mirror - works just fine.
According to Mike Valentine... the higher, the better (as long as the line of sight to the radar source isn't obscured - which it isn't).
Old Nov 20, 2008 | 08:27 AM
Eric (Plug Guy)
Here 'tis.....in the flesh:
Old Nov 20, 2008 | 01:48 PM
benji_mini's Avatar
benji_mini
thats where mine is aswell. does having tint on my windows decrease the accuracy of the valentine? my rear window is pretty dark - 20% charcoal tint with 20% chrome tint behind it - got a design thrown up in the back wind sheild.
Old Nov 20, 2008 | 03:08 PM
marshall07's Avatar
marshall07
what did you guys use to mount your V1 to the left of the mirror. i am going to do that as well.... also, where did you tap your power supply? ill do a search for a write-up, but i thought i'd ask the question here first...
Old Nov 20, 2008 | 03:24 PM
RaceTripper
I have mine in the same place. Right now I'm just using the windshield suction cup mount, but would like something without windshield mounting that keeps the V1 i the same place.
The power is easy-peasy. Taps into the power for the map lights in the headliner console. There is a complete writeup with pictures here on NAM somewhere, I think in the 2nd Gen electrical mods forum.
Old Nov 20, 2008 | 03:52 PM
benji_mini's Avatar
benji_mini
i tapped in somewhere near the sunroof, not sure exactly. the entire install took less than 20 minutes. mine is mounted with the windsheild suction cup thing as well, which im not too fond of but i live with. i will eventually get the rear view mirror thing mentioned earlier in this thread.
Old Nov 20, 2008 | 04:26 PM
Performance Angst
I also plan to tint the top of the front windshield. At that point mounting above the mirror is a dad option. I am going to work on a few companies and see if they would be interested in making a below the mirror mount for us. If not, I'm going to fabricate something out of the available parts.
Old Nov 20, 2008 | 04:47 PM
RaceTripper
When I had my M3, I mounted my V1 behind the tint on the top of the windshield. It worked just fine. Never had a problem in 3.5 years of use.
Old Nov 20, 2008 | 06:04 PM
toolazyforalogin's Avatar
toolazyforalogin
Remember the higher it is the less laser you pick up and more chance you have of missing radar/laser from the rear....although radar should bounce off the objects in front of you and reflect so that you pick it up....although then the $100 arrows will be pointless.
If being stealth is not a necessity then you may consider my setup through the bezel and to the fuse box (using an add a fuse) which will give you the best coverage for front and rear:
Old Nov 20, 2008 | 06:10 PM
STaSISnRI's Avatar
STaSISnRI
MINE IS DONE THIS EXACT WAY!!! I love it
Old Nov 21, 2008 | 06:53 PM
Performance Angst
Hey folks
I have been conctacted by a party interested in designing an producing a mount that will allow installation of the detector below the mirror.
He really needs a rear view mirror from a MINI in hand to mock up the piece. Does anyone know where I might find a mirror to serve this purpose of mock up?
Old Nov 21, 2008 | 07:34 PM
big howe's Avatar
big howe
Hey folks
Is first gen the same as second? I have a 52 mirror laying around(auto dimming). I could be persuaded to part with it.
Old Nov 21, 2008 | 07:56 PM
RaceTripper
Hey folks
Mark me down as someone not interested in a below mirror mount. I think it will be too much in the way sitting there. I want mine above and to the left of the mirror, but I would like a mount that lets me keep it there so I can get rid of the suction cup mount.
Old Nov 21, 2008 | 08:56 PM
big howe's Avatar
big howe
IMHO, the upper right mirror mount of the unit and the remote display on the steering column is pretty cool. I think there's some pics in the first gen forum.
