16x8 rota rb + 35
What size tire do you WANT to run? What suspension and ride height are you running? Camber?
I run 16x8's no problem with an even lower offset but I'm running smaller tires to get some stretch for additional clearance.
Yah, but there is also a .6" difference between on the offset of those and the wheels you're looking at.
I think with that offset it's gonna be close but probably do-able. What size sidewall are you thinking about getting?
Ficcion runs 17x8 et38 235's on his r56 ...but he isn't lowered which may play a part in it....and he has 3mm more clearance than you will.
https://www.northamericanmotoring.co...2&postcount=51
With all that said, sticking with the 225's would make things much easier and unless your car is a competitive track car that you take out to races, the additional contact patch of the 235's won't be that noticable.
thanks rally , 225's it is, . I've also seen 16x8 RB's with an offset of 40, would they fit using a 225 tire?
To be honest, I'm not 100% sure.
I usually help people out with much skinnier tires on aggressive wheels. I haven't been able to test out fitting wide tires on wide wheels enough to know how much space is there on the R56 yet.
I know that when you get into the 40's on 8" wide wheels you have to start thinking about INSIDE clearance rather than just outside clearance.
DrFraserCrane
Aug 30, 2015 01:11 PM
thats what negative cambers are for tho..
