16x8 rota rb + 35
Old Nov 15, 2008 | 05:09 PM
PERNOR56's Avatar
PERNOR56
16x8 rota rb + 35
Would RB's with +35 offset fit the 08 S. using wheel size 16x8. Anyone out there know? What size tire can I run?
Old Nov 16, 2008 | 11:44 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
What size tire do you WANT to run? What suspension and ride height are you running? Camber?
I run 16x8's no problem with an even lower offset but I'm running smaller tires to get some stretch for additional clearance.
Old Nov 16, 2008 | 01:41 PM
PERNOR56's Avatar
PERNOR56
h&r springs 1.5 drop. stock camber, 235 wide tire. Is this possible?
Old Nov 16, 2008 | 02:53 PM
sprp85's Avatar
sprp85
235 will RUB.. especially for the back. I rubbed often when I ran et42 7.5 w/ 215/45s so 235.. will R-u-b. thats what negative cambers are for tho..
Old Nov 16, 2008 | 03:13 PM
PERNOR56's Avatar
PERNOR56
Was that on a R56? MachV runs 235 on 7.5 w et 45.
Old Nov 16, 2008 | 03:41 PM
Rally@StanceDesign
Yah, but there is also a .6" difference between on the offset of those and the wheels you're looking at.
I think with that offset it's gonna be close but probably do-able. What size sidewall are you thinking about getting?
Ficcion runs 17x8 et38 235's on his r56 ...but he isn't lowered which may play a part in it....and he has 3mm more clearance than you will.
https://www.northamericanmotoring.co...2&postcount=51
With all that said, sticking with the 225's would make things much easier and unless your car is a competitive track car that you take out to races, the additional contact patch of the 235's won't be that noticable.
Old Nov 16, 2008 | 03:51 PM
PERNOR56's Avatar
PERNOR56
thanks rally , 225's it is, . I've also seen 16x8 RB's with an offset of 40, would they fit using a 225 tire?
Old Nov 16, 2008 | 03:54 PM
Rally@StanceDesign
To be honest, I'm not 100% sure.
I usually help people out with much skinnier tires on aggressive wheels. I haven't been able to test out fitting wide tires on wide wheels enough to know how much space is there on the R56 yet.
I know that when you get into the 40's on 8" wide wheels you have to start thinking about INSIDE clearance rather than just outside clearance.
Old Nov 16, 2008 | 04:47 PM
PERNOR56's Avatar
PERNOR56
ok, so to be safe + 35 with a 225 / 50 tire.
Cheers , Thanks for your help
DrFraserCrane
Aug 30, 2015 01:11 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
Dashdog
Aug 10, 2015 06:17 AM
wheelspnr
11
Jun 23, 2005 12:54 PM
