Suspension Cross Coilover install problem
Old Nov 9, 2008 | 06:56 AM
terry glazar's Avatar
terry glazar
I purchased a set of Cross coilovers and went to do the installation on my 2008 MCS. When I tried to put the bottom of the CO into the suspension where the pinch bolt is I could not get it in. I measured the Cross and found it to be 52mm and the suspension hole at the pinch bolt is 51.4mm. The stock shock measured 51.2mm thus providing clearance. I tried to spread the suspension at the pinch bolt but was not successful. Has anyone had a similar problem and if so how did you solve it?
Thanks, Terry
Old Nov 9, 2008 | 07:28 AM
k-huevo's Avatar
k-huevo
Try inserting the sqaure end of a 1/4 inch drive extension in the lower edge slit from below and turn it 45 degrees; this should spread it enough.
Old Nov 10, 2008 | 08:12 AM
terry glazar
It worked like a dream. CO installed and working.
Thanks, I really appreciate your help and your quick response.
Terry
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 12, 2015 01:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
