Suspension THUNK! when hitting certain bumps...
Old Nov 8, 2008 | 07:00 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Coilovers: thunk! = improper preload? HELP!
Installed the Megans several weeks ago...still need to adjust the height of the rears and I'm having issues with bounciness.
Anyhow, when I hit a bump, I occasionally (7 of 10 times) will hear a loud, solid, THUNK from the passenger rear.
Took a look at it yesterday morning and there seems to be a bit of play in the spring...I can wiggle the spring and replicate the sound (albeit a much quieter thunk), so I'm thinking I need to tighten the two interlocking nuts at the bottom. NOTE: I can't wiggle any of the other coilover springs and the noise is isolated to the passenger rear.)
Is there an easy way to do this without having to remove the coilover? Will I need to apply slight compression to the spring as well?
Lastly, I had all the torque specs for the suspension saved as a word document, but the laptop crashed...so I would really appreciate having the torque specs again for:
Sway bar
Control arms
End links
Coilover (top 2 bolts)
Coilover (bottom single bolt)
Subframe
I figured while I'm under there I'd recheck all the torques...
Thanks!
Erika
Old Nov 9, 2008 | 12:53 AM
ninjlao's Avatar
ninjlao
Ninja Mini
Your sping doesn't have enough preload. The spring perch is hitting the spring on the rebound making the thunk sound. preloading your springs correctly will get rid of this.
Old Nov 9, 2008 | 05:35 AM
SNEEEZY - Erika
Rattle Can Queen!!!
Thanks for the reply...any tips on setting preload? (I'm going to search NAM in the meantime...)
Old Nov 9, 2008 | 05:38 AM
SNEEEZY - Erika
Rattle Can Queen!!!
I edited the thread title--hopefully some helpful NAMers will share their wisdom so I can get rid of the thunk.
I still need torque specs, too!
Thanks, everyone!
Erika
martinb
Oct 7, 2015 05:00 PM
navybsn
Oct 4, 2015 03:27 PM
ToroPerro
Oct 1, 2015 12:54 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
USA-RET
Sep 8, 2015 01:50 PM
