R50/53 Silly window question.
Old Nov 3, 2008 | 11:20 AM
pmustang's Avatar
pmustang
Is it possible to just have the window go down a tiny bit? I like a bit of a breeze and can't seem to finagle the window down just a half inch or so. I have a 2006 if that makes any difference. It goes into auto down mode or auto up when trying to set it, I can see me burning out the window motor trying to get it where I want it.
Many thanks. peter
Old Nov 3, 2008 | 11:28 AM
cobra94563's Avatar
cobra94563
my 2004 does.
Old Nov 3, 2008 | 11:47 AM
C-Lop's Avatar
C-Lop
if you push the toggle all the way down it goes into auto mode if you tap it down it only goes down a bit
Old Nov 3, 2008 | 10:12 PM
pmustang's Avatar
pmustang
thanks!!! I will try it in a less ham fisted manner on the way to work today.
cheers. Peter
Old Nov 4, 2008 | 06:27 AM
C-Lop's Avatar
C-Lop
actually i realized on my way home that i told you exact opposite of what I meant
Old Nov 4, 2008 | 07:18 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
If I want my window down 1/4" I have to press the button down to open the window about 2 inches and then bring it back up to 1/4". If you give a quick push down on the button it goes "auto down".
I also read about some computer software upgrade that will give you an "auto up". Has anyone heard of that??
I would like to have the "auto up" on my 05. Holding the up button after going through a toll booth in the winter is a PITA.
Old Nov 4, 2008 | 07:24 AM
Eric_Rowland's Avatar
Eric_Rowland
You need Ian Cull's (GBMINI) auto-up circuit.
http://www.gbmini.net/wp/auto-up_windows/
Totally rocks!
Old Nov 4, 2008 | 10:20 AM
pmustang's Avatar
pmustang
I have auto up and auto down, was unable to push the switch a little bit, its either on or off, and on makes it go auto down.
Peter
Old Nov 4, 2008 | 10:53 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
Totally rocks!
It does not look like he sells these any longer.
Old Nov 4, 2008 | 10:59 AM
beken's Avatar
beken
I believe, if you tap the toggle all the way down, then it goes all the way down. If you hold it down for more than a tap then let go, the window will stop going down when you let go.
If you only want it go barely go down, you tap down, then tap up.
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
