Small - LEAK, dime size (blue-ish fluid)
Old Nov 2, 2008 | 06:06 PM
LtRex's Avatar
LtRex
06 MCS, 40000 miles, just noticed a dime size fluid drop(s) on the garage floor. Fluid is blue-ish and has a petroleum kind of feel to it, and is kinda to the driver's side, front, 18" in from the driver's side front tire.
Any ideas what on earth this could be?
Old Nov 2, 2008 | 06:27 PM
LtRex's Avatar
LtRex
Just found the thread about the therm gasket leak. Seems to be a problem. I will call and make an appointment to get it looked at. Seems like that is what it is.
Old Nov 2, 2008 | 06:34 PM
Some Guy's Avatar
Some Guy
Good news is that it is a pretty quick fix. At 40k you should be covered under warranty no questions.
Old Nov 2, 2008 | 06:43 PM
LtRex's Avatar
LtRex
At this point, I am kinda leaning toward asking the local dealer to point me in the direction of an extended warranty company they deal with regularly. Just want to keep damages to a minimum and yes, less than 10K left on factory warranty.
Old Nov 2, 2008 | 09:02 PM
07BPB's Avatar
07BPB
I had the same issue in the same spot. As you have found out its probably a leaky thermostat. Just make sure your reservoir is still topped up and get the dealer to fix it.
Old Nov 13, 2008 | 04:38 PM
LtRex's Avatar
LtRex
Here is another drop. First one since the start of this thread. Looks like coolant to me, what say the majority? It has been 11 days and another drop. Hmm....
Old Nov 13, 2008 | 09:06 PM
07BPB's Avatar
07BPB
Looks like coolant to me.
Old Nov 13, 2008 | 11:58 PM
MLPearson79's Avatar
MLPearson79
Looks like coolant to me too. I had the thermostat housing replaced around 35k, it had a very small crack in it and would leak very slightly. It's a pretty common problem.
Old Dec 2, 2008 | 04:33 PM
NTACTUALSIZE's Avatar
NTACTUALSIZE
that just means you suck at motoring and its your mini actually crying because it wants to be pushed harder and harder
Old Dec 2, 2008 | 04:38 PM
LtRex's Avatar
LtRex
When I took it in, they were in the process of doing "7" of these!!!!
HELLO B M W ! ! ! Fix this!!!!!
Old Dec 2, 2008 | 05:07 PM
GreenR50's Avatar
GreenR50
Same issue here... 06 MC with a housing and thermostat replacement last week. 19k miles...
Old Dec 3, 2008 | 08:06 PM
gt489's Avatar
gt489
yup happens all the time with the thermostat housing. replaced 3 yesterday at work and 2 today.
Old Dec 25, 2008 | 10:07 AM
mcsc_horns's Avatar
mcsc_horns
I've got the same issue. Will be taking it in after Christmas
HaveATank
Sep 4, 2015 08:04 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
damncajun
Aug 17, 2015 08:25 PM
wind715
Aug 11, 2015 07:56 AM
pocketmaster
Aug 6, 2015 01:41 PM
