Suspension DOes anyone know the conversion between..
Old Oct 29, 2008 | 06:41 PM
minimyke's Avatar
minimyke
Does anyone know the conversion from metric to standard spring rates?
Im on summit and I want to order some Eibach fron coils for my megans, and all of the spring rates are standard..If nobody knows that, does anyone know a good SAE springrate to run?
Any replies are appreciated
Thanks, Myke
Old Oct 29, 2008 | 07:31 PM
batrugger's Avatar
batrugger
No, but the Megans that i bought awhile back had these on the front:
Fronts have 6" 440lb/in (7.85kg/mm) semi-barrel springs (Eibach) from Ground Control.
and then they used the stock rears.
Old Oct 29, 2008 | 07:56 PM
minimyke's Avatar
minimyke
Thanks wes, do you know if those 6
' springs are shorter than stock? BTW are you goin to the GTG the first monday of November?
Ryephile's Avatar
Ryephile
From Google: 1 kilogram / millimeter = 55.9974146 pounds / in
From my memory:
Spring rate in lb/in = spring rate in kg/mm divided by 0.0179
example:
X = 5 / 0.0179
X = 279 [lb/in]
Or:
250 = X / 0.0179
X = 0.0179 x 250
X = 4.5 [kg/mm]
I hope that helps!
Ryan
Old Oct 29, 2008 | 08:04 PM
minimyke's Avatar
minimyke
thanks for the quick replies I already found exactly what I'm lookin for : http://store.summitracing.com/egnsea...115+4294787575
Old Oct 29, 2008 | 11:39 PM
ScottRiqui's Avatar
ScottRiqui
Glad you found what you're looking for. Another handy option is to use Google. If you put a mathematical equation or conversion in the Google search window, it will automatically do the conversion for you.
For example, if you put in "440 lbs/in in kg/mm" or "440 pounds per inch in kilograms per millimeter" (without the quotes), the first search result will actually be the Google Calculator result "440 (pounds / in) = 7.85750562 kg / mm"
It knows all the weird units, too - if you put in "55 miles per hour in furlongs per fortnight" (again, without the quotes), it will return the correct conversion:
"55 miles per hour = 147,840 furlongs per fortnight"
Old Oct 30, 2008 | 07:17 AM
txwerks's Avatar
txwerks
A quick and dirty calculation is to multiply kg/cm x 5.7 to get to lb/in... e.g. 60 kg/cm x 5.7 = ~342 lb/in. Dividing lb/in by 5.7 gives you a rough kg/cm estimate, too.
Old Oct 30, 2008 | 04:00 PM
minimyke's Avatar
minimyke
thanks everyone i appreciate it
Old Oct 30, 2008 | 10:46 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I use dimensional analysis for this sort of thing. It makes it a lot easier.
Old Oct 31, 2008 | 07:02 AM
thatatvguy's Avatar
thatatvguy
Here's a link too. http://www.hraefn.net/projects/spring_rates.php That calcs the rates. Lengths: http://www.onlineconversion.com/length_common.htm
NYMADMINI
Dec 14, 2016 02:33 PM
Oct 1, 2015 12:13 PM
Sep 30, 2015 12:08 PM
Sep 29, 2015 12:11 PM
