R50/53 Coolent Dripping
Old Oct 29, 2008 | 01:15 PM
namvet66's Avatar
namvet66
Coolent Dripping
I have an 06 Mini. Lately I have noticed that green fluid (Coolant I think) drips on my carport floor.
The car is not running hot and check engine light nor any other warnings have appeared.
Any suggestions on how to check this out, or what might be causing this?
Any help will be appreciated.
Old Oct 29, 2008 | 01:26 PM
tfleury9's Avatar
tfleury9
I'd check your coolant resevior to see if the level is going down. Don't open it when the engine is hot though.
Looking down from the top of the engine, look to see if any coolant is leaking into the plastic pan under the radiator. It will pool there if your radiator or maybe a hose is leaking.
I had this happen with my car a couple of years ago, mine was an intermittent leak. As it turns out, the radiators are made from plastic and aluminum and I believe the bond between them got cracked or loose. It would seal itself when the car was hot and then drip a little when the engine cooled down.
Old Oct 29, 2008 | 01:37 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Common problem - see this thread:
https://www.northamericanmotoring.co...d.php?t=118242
Old Oct 29, 2008 | 01:41 PM
MCS06's Avatar
MCS06
Had the same problem. Still under warranty, brought it to the dealer.
They replaced the thermostat housing and gasket. No more leaks!
Old Oct 29, 2008 | 02:02 PM
namvet66's Avatar
namvet66
I checked the reservoir and looks to be almost empty. The hoses and under the radiator doe not appear to have any standing fluid or stains like there is a leak, but I have green coolant on my carport.
Now can you tell me what type of coolant I need to put in my Mini?
I guess maybe I need to talk to my dealer about this problem also.
Thanks for all your help and quick response.
Old Oct 29, 2008 | 02:10 PM
namvet66's Avatar
namvet66
Thanks for your reply. I am calling my dealer and getting an appointment to take care of this problem, still under warranty.
Old Oct 29, 2008 | 03:46 PM
namvet66's Avatar
namvet66
Appointment at 9 AM tomorrow to get leak checked out and repaired. I said I was still under warranty, I hope this is a warranty item.
Old Oct 29, 2008 | 04:51 PM
MCS06's Avatar
MCS06
namvet66: My expansion tank was almost dry before going to dealer. As far as coolant goes, I added MINI coolant that I had purchased on a prior visit. You may find varying opinions on type of coolant, but I am absolutely crazy about this car and OCD, so I didn't want to take any chances!
BTW, the repair was covered under warranty...so no charge.
Good luck!
Old Oct 30, 2008 | 03:41 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
Same here!
Old Oct 30, 2008 | 04:50 PM
namvet66's Avatar
namvet66
Took mine in today and sure enough, it was the thermostat and gasket, changed and under warranty.
Thanks to all the replies from you folks, it was a great help.
USNAE2
16
Jun 17, 2022 07:17 AM
elverado
Jan 18, 2022 02:51 AM
ian260
Mar 29, 2017 06:08 AM
cjny
Sep 21, 2015 01:28 PM
rikaro
Sep 21, 2015 06:57 AM
