How can I tell if I have a metal or rubber valve stem?
Old Oct 16, 2008 | 12:44 AM
fm.illuminatus's Avatar
fm.illuminatus
Hi, I just ordered a new set of tires for the car, and when I went down an checked, it looked like they were metal (they have kind of a bolt pattern around them, and were really solid)... so I ordered new tires with metal valve stems.
However, now I'm having second thoughts, did I do right? Does it matter really? And if it does, how do I know if I've got metal or rubber stems?
Old Oct 16, 2008 | 01:29 AM
pilotart's Avatar
pilotart
USA spec MINI's following August 2007 have Federal Mandate Tire Pressure Monitor System.
This is attached to special metal 'valve stems' which also serve as antenna and should have plastic caps.
Old Oct 16, 2008 | 05:59 AM
tim781996's Avatar
tim781996
Try biting it. If it hurts, it's metal.
Old Oct 16, 2008 | 07:02 AM
matty125's Avatar
matty125
If you look at your wheel where the valve stem is it should have a round metal disc as a cap. This is the newer TPMS. If you change wheels you will need to remove these and put in your new wheels. My FEB 07 build has a TPMS with the rubber valve, on this model the TPMS is actually a circumference measurement in the brake, it monitors the speed of rotation which will deduce pressure differences.
Old Oct 16, 2008 | 07:23 PM
jw34's Avatar
jw34
Good one.
Old Oct 16, 2008 | 08:06 PM
rrcaniglia's Avatar
rrcaniglia
You can't be talking about the valve cap. You're saying the TPMS is a disc of some sort under the rim (on the inside) at the base of the valve stem?
My valve stem caps were disc-shaped plastic. One is now missing and replaced by the local tire shop with a small bullet-shaped metal cap. I've had no issues with the tire pressure warning system giving me alarms.
Old Oct 16, 2008 | 11:54 PM
matty125's Avatar
matty125
the actual sensor is inside of the wheel yes. Your metal valve stem is what your "disc" screw onto
Here is a link to the TPMS that Tirerack sells http://www.tirerack.com/accessories/...toring+Systems
Old Oct 17, 2008 | 09:17 PM
fm.illuminatus
Well, I ordered the car at the end of August so... I'm guessing metal?
Old Oct 17, 2008 | 09:19 PM
fm.illuminatus
I'll get right on it.
Old Oct 18, 2008 | 05:08 AM
cristo's Avatar
cristo
Alliance Member
Try looking at the valve stem.
If it's metal, you have a metal valve stem.
If it's rubber, you have a rubber valve stem.
Old Oct 18, 2008 | 05:33 PM
rrcaniglia's Avatar
rrcaniglia
Is there any difference in taste?
Old Oct 18, 2008 | 06:39 PM
Oxybluecoop's Avatar
Oxybluecoop
Old Oct 18, 2008 | 07:44 PM
rkw's Avatar
rkw
Yep, there is no mistaking a black rubber stem.
However, I don't think you need new stems when replacing the tire (just reuse the old stems). You probably won't even be able to use the new stems you ordered -- they would have to be compatible with the BMW TPMS sensors.
Old Oct 19, 2008 | 06:09 AM
Lil Blue Coop/Mini Rose's Avatar
If the Mini TPMS are anything like Dodge, you will need an install kit. On my Magnum there is a rubber washer and metal crush washer that will distort when installed. You cannot reuse these. Dodge has a kit with the replaceable parts for TPMS reuse.
BernieCoop
Sep 10, 2021 03:15 AM
CaptKen
R59 :: Roadster Talk (2012+)
11
Oct 21, 2015 06:32 AM
Sc00terbum
Sep 11, 2015 07:17 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 2, 2015 09:05 AM
