Need to replace radiator..what options do I have?
Old Oct 14, 2008 | 08:01 PM
agile_moments's Avatar
agile_moments
So...I had some recent overheating problems in my 02 MCS. I've fixed them, but now Im losing coolant bad due to a cracked radiator. What are the best options for a replacement radiator as far as where to find one?
I'll be doing the install myself, I just need the rad. I've found one @ carparts.com for 200 shipped. Anything else?
Old Oct 20, 2008 | 08:03 AM
MaxyMini's Avatar
MaxyMini
Hi Agile,
Did you replace the rad? If you have, please tell me if it was horribly hard and do I need a dealer to do it? Thanks.
Old Oct 28, 2008 | 01:51 PM
goldcountrymini's Avatar
goldcountrymini
I'm interested in this as well... I noticed my coolant level is constantly dropping so I figure I have a leak somewhere. Anyone know how to find that leak? I figure I'll have to replace the radiator or possibly a hose from the resevoir or something
Old Oct 28, 2008 | 03:05 PM
MaxyMini's Avatar
MaxyMini
Leaking coolant
I got my car fixed. It was leaking coolant all the time. When I took it to my mechanic (non-Mini), he could not find the leak so I took it to the dealer. It turned out to be a bad thermostat (who knows where the coolant was leaking from). Anyway, the dealer changed it under warranty and said that this newer thermostat was better than the older version. I have a 2005 MCS.
I hope this helps.
Old Oct 30, 2008 | 01:15 PM
1FSTMINI's Avatar
1FSTMINI
1-800-500-5010 Quick Cool....The guys name is Bob. very nice guy and cheapest anywhere.
EDIT: well i guess not with this part. He said $200 is very cheap.
Old Nov 3, 2008 | 09:58 AM
kenatminimania's Avatar
kenatminimania
All Aluminum performance radiator for the Cooper S.
Old Nov 3, 2008 | 05:36 PM
MINICHEF's Avatar
MINICHEF
http://www.pwr-performance.com/auto_main.htm
CHECK THIS OUT AND YES IT DOES FIT UP TO 06 MINI
Old Nov 3, 2008 | 05:58 PM
Eric_Rowland's Avatar
Eric_Rowland
Hey GCM! As Maxy said, check the thermostat first (and the coolant tank second) for leaks. Much more likely than the radiator.
Old Nov 4, 2008 | 10:30 AM
PenelopeG3's Avatar
PenelopeG3
Your local Autozone should have a coolant system pressure tester that it will rent (for free). Use this before wasting money on parts that might or might not be necessary. This will help identify where the leak is coming from.
btw PWR radiators are excellent. The price on the minimania rad is scary
Old Nov 4, 2008 | 11:12 AM
kenatminimania
Yes, our radiator is pricey - thanks to the current exchange rates with the UK...
If you go with PWR, make sure it's the Cooper S version - they make good products.
Ken
boostedhaze
Jan 2, 2018 07:26 PM
Minibeagle
Aug 13, 2015 10:00 AM
Aug 12, 2015 01:24 PM
pewx3
Aug 7, 2015 03:34 PM
