Suspension Slammed/Lowered with xenon levelers
Old Oct 13, 2008 | 03:38 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Has anyone had problems with their xenon auto-level sensors and super low ride heights? I haven't checked mine closely yet, but I was curious if anyone knew whether there was a maximum range for their movement or not.
If so, has anyone made extensions for the sensor arms? It looks like it'd be pretty easy to make.
Old Oct 13, 2008 | 06:30 PM
Creeve's Avatar
Creeve
Rally have we seen a thread about your MCC on NAM yet? I only think I've seen it on M/U. Cause when you say your slammed I doubt people really understand to what extent. As to your question sadly I am of no help, I am not sufficiently lowered nor xenoned yet. One day if all goes to plan.
Old Oct 13, 2008 | 07:33 PM
Rally@StanceDesign
hahah I've posted a little about it in the clubman forum. I was just hoping that someone out there knew a little about the sensors and their limits. This is the first car I've ever had with xenons so the sensor system is totally new to me.
For the record though, this is in regards to a car that is really really lowered...probably upwards of 6 inches lower than stock.
Old Oct 14, 2008 | 06:34 PM
ghosthound's Avatar
ghosthound
wow, thats really low...
Old Oct 15, 2008 | 05:22 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Please post a pic! I'd love to see how that looks!!!
Old Oct 15, 2008 | 08:08 AM
Rally@StanceDesign
Bumper rests on the ground, jack points are about a finger gap off the ground. Still working on getting it lower. I've got some plans to machine some custom mounts and lower it another 1-2 inches. The 6 inch lowering number that I threw out there will be where it sits AFTER these mounts are installed. Right now, it sits about 4-4.5" lower than stock based on the arch->ground measurements.
Old Oct 15, 2008 | 08:09 AM
Rally@StanceDesign
Bump for answers to the question. Anyone know anything about how these sensors work?
Old Oct 15, 2008 | 08:26 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
You might check or ask on the 1st Generation / suspension forum as they have a lot more slammed MINI's.
Old Oct 15, 2008 | 12:13 PM
jamescalland's Avatar
jamescalland
What the heck have you used to slam it that far, i want them, i need them, i love it!!!!!!!!!!!!!
Old Oct 15, 2008 | 05:01 PM
ghosthound's Avatar
ghosthound
how does that thing drive? it looks like theres no travel left at all!!
Old Oct 15, 2008 | 05:24 PM
glnr13's Avatar
glnr13
hahahaha what makes you think that suspension is fixed at that height?
Old Oct 15, 2008 | 06:09 PM
rrcaniglia's Avatar
rrcaniglia
I hope it doesn't rain in your area. There is a thread somewhere here on NAM that talks about hydrostatic lock of the engine from water ingestion when traversing puddles 4"-6" deep.
Old Oct 15, 2008 | 06:25 PM
Rally@StanceDesign
They're custom struts. They have quite a few inches more travel than the OEM or aftermarket MINI struts/coilovers My rears have have 5.6" of travel which is a far cry from the 1.5" of travel that a non-lowered OEM MINI has
Somehow missed that thread. Where is the water getting in?
Either way, deep water is no issue...
Old Oct 15, 2008 | 06:26 PM
Rally@StanceDesign
off-topic discussion aside........does ANYONE know about the xenon sensors/servos????
Old Oct 15, 2008 | 07:23 PM
rrcaniglia's Avatar
rrcaniglia
On topic: the thread on water ingestion indicated the air intake is located low. The OP for the thread stated they had slowed down to walking speed to traverse a puddle that did not swamp the cabin after the car had died mid-stream and the door was opened. A poster observed that the door sill in a MINI is 6 inches above the roadway and that the MINI manual said it could cross 6 inches (I think-haven't looked myself) if done slowly. Ergo, the hydro-lock shouldn't have happened.
Still, the result, was a hydro-locked engine. Another poster gave a similar story. Both were out $8k for a new engine since this is not covered by warranty.
Off topic: No. But am interested since I have same headlights.
Old Oct 15, 2008 | 11:08 PM
rkw's Avatar
rkw
Regarding leveler operation, it's much more a matter of front/rear rake than overall suspension height. If you can set the beam cutoff to perfectly level and still have room to adjust it further, you should be okay. As a general rule, you can't aim the beam cutoff much higher than level because at some distance it will glare into rear windows. Here are detailed instructions for aiming headlights: http://www.danielsternlighting.com/tech/aim/aim.html
Old Oct 17, 2008 | 09:49 AM
Rally@StanceDesign
Thanks RKW.
My aim is perfect and my rake while driving is just about the same as stock. My main concern is just that the arms are too short and it's gonna break them if I go any lower. The servos/sensors are attached at the body/subframe while they're connected to the front and rear lower control arms. Mine almost look like they're straining since the angle of the control arms has been altered so much.
Old Oct 17, 2008 | 07:31 PM
Ryephile's Avatar
Ryephile
Rally: The levelers, as RKW stated, work relative to each other. They are potentiometers, and present an impedance delta to the HID levelers which determine if the beams need to be raised or lowered. I would imagine you should be able to extend the lever arms, and as long as you do so equally [proportionally] to the front and rear arms, the levelers will operate identically to stock. If I were in your shoes I may try to relocate the leveler boxes to be centered within your suspension travel similar to stock, as that may be easier than fabbing new arms.
If you want to go nuts, you can remove both leveler boxes completely. I did this on my '02 when I installed tubular control arms front and rear. What happens to the leveler motors is they park full down [at least on the R50/53 HID], and from there you manually adjust the headlights as desired. Since you probably plan on using your airbags actively, you probably don't want to go this route, as you actually want your levelers to work, right?
Old Oct 17, 2008 | 11:39 PM
Rally@StanceDesign
Thanks for the insight ryan I would like to keep them working so I'll fool around with some longer arms. They shouldn't be too hard to fab up and test out
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
Emnotek
Sep 29, 2015 07:37 AM
