Suspension R53 coilovers on R56
Old Oct 9, 2008 | 11:31 AM
Bl4ze87's Avatar
Bl4ze87
Hi all!
I ve read only rumors, and now i have a biiiig question!
Is possible to mount on my cooper d my07, R50/53 coilover? (like this https://www.minimaniac.info/shop/RSX...-Bj06-01-03-02 or like kony fsd)
And if possible, i need to change springs, or the original from the coilover will be good?
Sorry for my english
Thanks in advance!
Old Oct 13, 2008 | 02:48 AM
Bl4ze87's Avatar
Bl4ze87
Any good news? :p
Old Oct 13, 2008 | 11:15 PM
FugitiveAI's Avatar
FugitiveAI
Originally Posted by Bl4ze87
Hi all!
Thanks in advance!
I'm not sure about those since they are only for 02-03 models (maybe it's all the same, I'm just not sure), but most R53 2002-2006 models should fit. You will probably need adapter bushings for the rear coilovers and possibly wheel spacers. You might have fitment issues that require more customization. I think most people would recommend sticking with coilovers made for the R56 for best results all the way around. I do see different spring rates on most R56 coilovers than the R53's so they may not be optimal.
Old Oct 14, 2008 | 12:36 PM
Coen_de_K's Avatar
Coen_de_K
I had my 2003CooperS coilover KW vI fitted on my Cooper... You only need these to fit them on your rears...
http://www.outmotoring.com/mini-coop..._bushings.html
The rest is just straight forward!
Coen
Old Oct 14, 2008 | 12:37 PM
Coen_de_K's Avatar
Coen_de_K
result is great and it does fits easily..
Don't forget to post pics!
Coen
Old Oct 14, 2008 | 04:55 PM
Bl4ze87's Avatar
Bl4ze87
Coen
So, i need only Gen 2 Rear Lower Shock Bushings, and i can fit them without problem?
Old Oct 15, 2008 | 12:21 AM
Coen_de_K's Avatar
Coen_de_K
Yes sir!
Coen_de_K's Avatar
Coen_de_K
But I would only do this with coilovers so you can adjust the ride height... but that's all! :D
Teh
Aug 22, 2022 04:37 AM
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Hippiehobbit267
Dec 3, 2019 04:22 PM
luisfv56
Aug 22, 2015 12:42 PM
Aug 12, 2015 01:24 PM
