Correct wheel size
Old Oct 5, 2008 | 08:14 AM
sergeibelski's Avatar
sergeibelski
Correct wheel size
Hello,
I know there are some threads similar to this but after reading for a couple of days I'm still confused and not sure with what to go.
I have a 2008 Mini Cooper (regular) with 195/55R16 run on flat tires.
I'm looking for winter tires and wheels in 15" not run on flat. I was told buy two different shops that I need two different size wheels. One shop said 175/65R15 and one 195/60R15.
What would be the right size for me? Will they both work? I know one is narrower so will I feel the difference?
Would really appreciate your input!
thank you very much,
Sergei
Old Oct 5, 2008 | 08:55 AM
ScottRiqui's Avatar
ScottRiqui
Of the two choices you listed, the 195/60R15 would be closer in diameter to your stock tire, but 185/65R15 would be an even better choice if you can get tires in that size - the overall diameter is closer to your stock tire, plus the taller sidewall will make for a softer ride.
Check out this tire calculator and you can play around with different non-stock sizes.
Old Oct 5, 2008 | 03:49 PM
sergeibelski
Thank you very much, I will take these numbers to the tire shop and see what they will say
Sergei
Old Oct 5, 2008 | 03:58 PM
ScottRiqui's Avatar
ScottRiqui
You're welcome - looking into it a bit more, it appears that the stock 15" tires are 175/65R15. Considering that these will be your winter wheels/tires, the narrower tread might be a benefit.
Old Oct 5, 2008 | 04:40 PM
mansize's Avatar
mansize
If you can find the 175/65R15 these would be a great choice. When I was buying, four winters ago, this size could not be found, so I went with a 185/60R15 size. I have been happy with them (Toyo Observe G-02 plus), but this is also a rare size, as it seems all MINI tires are. The 195/60R15 size should be a last resort, narrower is better.
Old Oct 5, 2008 | 09:47 PM
sergeibelski
I did find 175/65R15.. just a little scared that they are much narrower. We don't really have lots of deep snow in the minter but I am scared of the icy conditions and packed snow. Not sure if the narrow tires would be better or worse :(
Old Oct 7, 2008 | 10:15 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Narrow tires would be fine. Cuts through deeper snow better than wider tires.
Should be OK, just drive a little slower and carefully.
Old Oct 7, 2008 | 11:03 AM
sergeibelski
I see the advantages of the narrow tires but what are the disadvantages of the narrower tires? Anyone can tell me?
thank you,
Sergei
Old Oct 7, 2008 | 11:08 AM
mansize's Avatar
mansize
Disadvantage : less grip during spirited cornering on dry or wet roads during warm spells. Not usually a concern, as the relative "spongy" feeling of the winter tread compound does not promote spirited cornering anyway.
Old Oct 7, 2008 | 11:12 AM
sergeibelski
I'm usually a speed limit driving kind of guy so high speed driving during the winter usually doesn't bother me that much.. Any other disadvantages or reasons to go with a wider tire?
Thank you very much for all your help!!!
Sergei
Old Oct 7, 2008 | 02:08 PM
minihune's Avatar
minihune
Sergei
If you drive the speed limit you should be fine with any width tire.
In the dry or wet the wider tire can be helpful for traction and handling.
In the winter you can do OK at slower speeds.
Some tires summer or all season only come in certain sizes- depends on which tires. Some tire companies limit sizes so tire selection can be a factor if you really want one brand over another or your local shop only carries certain brands.
Old Oct 8, 2008 | 11:07 AM
sergeibelski
Thank you very much for all the help!
I just purchased a set of winter wheels/tires . I went with Yokohama Ice Guard IG20. Size 175/65R15.
thank you,
Sergei
Old Sep 29, 2009 | 04:46 AM
CMG's Avatar
CMG
I tried to start new thread but wasn't allowed..
will these 17" off an 06 (on 03 now) fit my 08 S?? getting them for $300 which seems like a deal
thanks
Old Sep 29, 2009 | 04:52 AM
ScottRiqui's Avatar
ScottRiqui
Yes, they'll fit fine. The bolt hole diameter, centerbore size and bolt pattern haven't changed over the years.
Old Sep 29, 2009 | 10:35 AM
Robin Casady's Avatar
Robin Casady
Do you mean the bolt hole in those wheels, or lug bolt hole used by MINI? Sometime in 2006 MINI changed from 12mm lug bolts to 14mm lug bolts. Some older wheels have lug holes large enough for 14mm bolts, some don't.
Old Sep 29, 2009 | 10:51 AM
ScottRiqui's Avatar
ScottRiqui
The diameter of the MINI lug bolts changed in 2006, but I've *never* seen an OEM MINI wheel that wouldn't work with either size bolt. On all the MINI wheels I've measured (both pre- and post-switchover), the bolt holes are always right around 16 mm.
I can't swear that all of the older MINI wheels will work with the direct tire pressure monitoring system (TPMS) found in the later cars, but there won't be a problem with the bolt holes.
Old Sep 30, 2009 | 02:14 AM
CMG's Avatar
CMG
thanks all
Kimolaoha
Dec 5, 2020 09:32 PM
col127
Aug 21, 2015 02:11 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
