Drivetrain Pre-Intercooler Chargepipe - M7
Old Oct 2, 2008 | 01:22 AM
sk8erguyzach's Avatar
sk8erguyzach
anyone have this?
http://www.m7tuning.com/parts/produc...roducts_id=110
any problems with it collapsing under high boost?
Old Oct 2, 2008 | 01:56 AM
donuttang's Avatar
donuttang
i just got it installed, under stock boost...it just get rid of the plastic in between, but feel a bit direct when step on it.....
how high you boost u are expecting?
Old Oct 2, 2008 | 02:49 AM
JAceMin's Avatar
JAceMin
The pipe would be pressurized as it is downstream of the turbo, so no chance it would collapse. It is pretty thick walled so while it may swell slightly that wouldn't be an issue either. I have one, fits nice, seems to have made a minor difference, and looks a lot cleaner.
Old Oct 2, 2008 | 06:46 AM
slinger688's Avatar
slinger688
Originally Posted by sk8erguyzach
anyone have this?
Curious, but what are you thinking of doing to your car?
Old Oct 2, 2008 | 11:20 AM
sk8erguyzach
im doing mod after mod until im satisfied with its power
Old Oct 2, 2008 | 11:59 AM
MotorMouth's Avatar
MotorMouth
Originally Posted by M7Tuning website
On the dyno, installation of the M7 Pre-Intercooler Charge Pipe resulted in gains of 3.6 horsepower and 11.3 ft-lb of torque AT THE WHEELS!
Old Oct 2, 2008 | 12:10 PM
myminirox's Avatar
myminirox
How was the install? Were you able to do it by simply moving the coolant reservoir, or did the upper grill have to come off too (not a big deal, but I hate messing with those plastic clips!)? Did you have to remove the bumper cover or was it enough to get under the car to install on the intercooler side?
Old Oct 2, 2008 | 02:15 PM
slinger688's Avatar
slinger688
Do not remove the bumper. The torx screw for the muffler is a PITA. Need to get access from the bottom. About 1-1.5 hours.
Old Oct 2, 2008 | 02:28 PM
myminirox's Avatar
myminirox
This is what I figured, which is why I've been delaying this one........
Old Oct 2, 2008 | 02:43 PM
slinger688's Avatar
slinger688
It is much easier the second time. Perhaps you can find a NAM member who has done it already that is close to you to help. I would but I am 3000 + miles away. If you do get to New York City area, I will be happy to help.
Old Oct 2, 2008 | 02:44 PM
JAceMin's Avatar
JAceMin
Don't be silly, I jacked the car up, you easily access the torx screw from below, use a ratchet torx adapter, move the expansion tank out of the way up top. The whole job including washing my hands took 15 mins. Easy.
Old Oct 2, 2008 | 02:48 PM
myminirox's Avatar
myminirox
thanks for the offer!
Motoring to NYC is tempting, but it will have to wait. In the meantime, any wisdom you can share about this mod would be very appreciated!
If there's anyone reading who'd like to help, send me a PM.
Old Oct 2, 2008 | 02:55 PM
sk8erguyzach
well i actually went a different way on this one
i just bought this
http://altaminiperformance.com/produ...be-Upgrade-Kit
figured i spend a lil more and get both the hot and the cold side pipes
Old Oct 2, 2008 | 03:03 PM
myminirox's Avatar
myminirox
i just bought this
When do you plan on installing?
I expect you'll gain some wisdom to share...
slinger688's Avatar
slinger688
I am curious whether mods are linearly additive in terms of their gains.
For example: Chip = 15 hp, exhaust = 12 hp, intake = 10 hp, so I will get 37 hp
I feel that they may not be.
Old Oct 2, 2008 | 03:09 PM
MotorMouth's Avatar
MotorMouth
we all wish but it doesn't work that way =(
Old Oct 2, 2008 | 03:12 PM
slinger688's Avatar
slinger688
i just bought this
Then you will need to buy one of these, a hose pick:
Old Oct 2, 2008 | 03:33 PM
slinger688's Avatar
slinger688
Thanks so much for that pointer. I was just making the point in an indirect way that you need an objective (track, showing off etc) and a plan otherwise you will spend way too much money.
Old Oct 2, 2008 | 04:45 PM
sk8erguyzach
hopefully ill get it monday or tuesday and will definatly install same day
will take pics and notes on installing
Old Oct 3, 2008 | 01:11 AM
donuttang's Avatar
donuttang
it is very time consuming to unscrew that bolt from the pipe. well, i tried both from the top and from the bottom....i finally ended up to start from the bottom, then, from the top to unscrew it....you have to get the small but not too small wrech type Torx T25(as i recall) to unscrew it, may be mine is an auto, the space is quite tight and the coolant hose is on its way to unscrew......but finally.............it worths it.....
Old Oct 13, 2008 | 03:10 PM
Derosi's Avatar
Derosi
Did it come with new clamps
I noticed that Alta sells this part also and provides new hose clamps. I recieved my M7 tube but did not get hose clamps can the factory ones be used effectively. Secondly it seems this install is much more touchy and time consuming than it seemed to me originally. Does anyone think a dealer could possibly give me a problem with warranty on this part because it seems it is to difficult to easily install and uninstall.
chrunck
R60/61 Cooper S Drivetrain
23
Jan 4, 2020 08:56 AM
my1stR56S
Feb 1, 2014 09:35 AM
PenguinOnTheTelly
Dec 30, 2013 03:01 PM
M7
Oct 1, 2007 07:20 PM
