Drivetrain Pre-Intercooler Chargepipe - M7
anyone have this?
http://www.m7tuning.com/parts/produc...roducts_id=110
any problems with it collapsing under high boost?
The pipe would be pressurized as it is downstream of the turbo, so no chance it would collapse. It is pretty thick walled so while it may swell slightly that wouldn't be an issue either. I have one, fits nice, seems to have made a minor difference, and looks a lot cleaner.
anyone have this?
How was the install? Were you able to do it by simply moving the coolant reservoir, or did the upper grill have to come off too (not a big deal, but I hate messing with those plastic clips!)? Did you have to remove the bumper cover or was it enough to get under the car to install on the intercooler side?
This is what I figured, which is why I've been delaying this one........
It is much easier the second time. Perhaps you can find a NAM member who has done it already that is close to you to help. I would but I am 3000 + miles away. If you do get to New York City area, I will be happy to help.
Don't be silly, I jacked the car up, you easily access the torx screw from below, use a ratchet torx adapter, move the expansion tank out of the way up top. The whole job including washing my hands took 15 mins. Easy.
thanks for the offer!
If there's anyone reading who'd like to help, send me a PM.
well i actually went a different way on this one
i just bought this
http://altaminiperformance.com/produ...be-Upgrade-Kit
figured i spend a lil more and get both the hot and the cold side pipes
i just bought this
i just bought this
i just bought this
When do you plan on installing?
I expect you'll gain some wisdom to share...
I am curious whether mods are linearly additive in terms of their gains.
For example: Chip = 15 hp, exhaust = 12 hp, intake = 10 hp, so I will get 37 hp
I feel that they may not be.
we all wish but it doesn't work that way =(
i just bought this
i just bought this
Thanks so much for that pointer. I was just making the point in an indirect way that you need an objective (track, showing off etc) and a plan otherwise you will spend way too much money.
hopefully ill get it monday or tuesday and will definatly install same day
will take pics and notes on installing
it is very time consuming to unscrew that bolt from the pipe. well, i tried both from the top and from the bottom....i finally ended up to start from the bottom, then, from the top to unscrew it....you have to get the small but not too small wrech type Torx T25(as i recall) to unscrew it, may be mine is an auto, the space is quite tight and the coolant hose is on its way to unscrew......but finally.............it worths it.....
Did it come with new clamps
my1stR56S
Feb 1, 2014 09:35 AM
PenguinOnTheTelly
Dec 30, 2013 03:01 PM
