225/50/15
Old Sep 14, 2003 | 03:13 AM
bodinski's Avatar
bodinski
i'm about to purchase a set of alessio F1s in 15x7 w/ +38 offset. my mcs has stock suspension, and i'd really like to run 225/50s. any chance this size tire will fit?
peace - bodinski.
Old Sep 15, 2003 | 08:17 AM
Alex@tirerack's Avatar
Alex@tirerack
it will mabey need a fender lip shaving. 225 requires that sometimes, and thats a fairly aggresive offset combination.
Alex
Old Sep 15, 2003 | 09:22 AM
bodinski's Avatar
bodinski
thanks for the info, alex. i understand that the mille miglia spider ii comes in a 15x7 +45. going to the +45 should alleviate the fender problem. is it likely, then, to rub the strut? also, can you find out the weight of the spider ii? sorry to be a pain - bodinski.
Old Sep 15, 2003 | 10:02 AM
Alex@tirerack
Et 45 on 15x7 should be a solid fit. 225 and lowering with that offset may rub lower shock perch.
25 LBS a wheel on 17 inch spider II.
Alex
Old Sep 17, 2003 | 07:09 PM
dpayne1's Avatar
dpayne1
I ran 225/50/15's (BFG gForce TA-KD) for autoxing this year on 15x7 Kosei wheels. Not sure of the offset, but even lowered there is no rubbing.
Now -- for performance - not looks -- If I had it to do over again I'd have run 205/50/15's BFG's instead. The 225/50 is a higher sidewall than 205/50, and the car had a tendancy to bounce the front under hard cornering. We had none of this "bounce" when running 205/50/15 Falken Azensis.
Old Sep 18, 2003 | 05:16 PM
bodinski's Avatar
bodinski
thanks for your help, folks. i broke down & ordered a set of michelin pilot h4s in a 195/60/15. i think they'll be plenty wide and will likely ride better than the yokos & dunlops i was looking at.
bodinski
cube17576
Tires, Wheels, & Brakes
Jan 10, 2008 09:56 AM
Iautox
11
Jun 11, 2007 06:32 PM
'*Ace*'
Nov 14, 2006 02:35 PM
sonichris
14
Jun 28, 2005 05:19 PM
