R50/53 Shift Knob Loose Help
Old Sep 22, 2008 | 11:55 AM
bobbyb714's Avatar
bobbyb714
Shift **** Loose Help
I have a 06 s 6 speed and my shift **** has some play in it .I would like to fix it but before i do the shift **** pull i want to know if it goes back on the same way .Also if anyone else has had this problem have they come up with something of a fix? Tks .If you have pics of the fix that would be good.
Old Sep 23, 2008 | 08:03 PM
AutoXR53's Avatar
AutoXR53
short throw shifter time Thats what I would do if I was you
Old Sep 24, 2008 | 04:59 AM
bobbyb714's Avatar
bobbyb714
Well that is one way .But i want to fix this if possible and keep oem.
Old Sep 24, 2008 | 07:20 AM
Doug W's Avatar
Doug W
The **** simply pops back on.
What kind of play are you having?
If it's vertical, the plastic tabs in the bottom of the **** may be either loose or broken.
If it's a twisting motion, the molded plastic key inside the **** must be broken.
Old Sep 24, 2008 | 08:04 AM
bobbyb714's Avatar
bobbyb714
Thanks for that info .It's a very slight twisting motion which is a pia.Anyway to fix this plastic key (crazy glue ) maybe .I have a large hand and the fit to the hand feels good .
Old Sep 24, 2008 | 08:23 AM
Doug W's Avatar
Doug W
I think I would try shimming the slot in the top of the shift lever with some thin material.
That would give a tighter fit between the slot and the plastic key.
Old Sep 24, 2008 | 11:23 AM
bobbyb714's Avatar
bobbyb714
Thank you for the advise will give it a try .
Old Sep 26, 2008 | 07:16 AM
Liquid's Avatar
Liquid
My **** is the same way. I bought some cheap "hockey stick tape" not sure what it's really called but it's the rough vinyl type tape you wrap a hockey stick with...got some in black and wrapped like one or two times around the shaft and it's "snug as a bug in a rug" now :-)
Old Sep 26, 2008 | 04:21 PM
bobbyb714's Avatar
bobbyb714
Thanks .
Old Sep 28, 2008 | 09:01 AM
bobbyb714's Avatar
bobbyb714
Hay Liquid it worked tks so much
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
OutMotoring
Mar 3, 2017 06:29 AM
gar56
Nov 15, 2016 06:41 AM
aldito2
Sep 30, 2015 10:44 AM
kevinlhr310
Sep 27, 2015 02:31 PM
