R50/53 Gas Cap
Old Sep 21, 2008 | 05:17 PM
frenchie's Avatar
frenchie
Gas Cap
Hello guys, The tether for my gas cap on my R50 came loose, not the end on the cap, the end that goes to the body somewhere, either to the gas door lid or the body. I cannot figure out where that end goes. Can someone please take a look and let me know if it goes to the gass door lid or some where on the body behind the door.....a picture would also be great if not too much trouble. Thanks.
Old Sep 21, 2008 | 06:14 PM
Montana Miniac's Avatar
Montana Miniac
The "tether" on my '02 MCS goes into the hole the hinge is mounted in. I suspect you will need to remove a interior panel to get to it from behind. Just a guess.
Old Sep 21, 2008 | 08:42 PM
frenchie's Avatar
frenchie
Thanks for the feedback!
Old Sep 22, 2008 | 06:04 AM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
The tether runs along the arm of the cap and sits in a notch at the base of the arm. With the cover open you can feel the notch at the opening were the arm goes through the black plastic base.
Old Sep 22, 2008 | 07:14 PM
frenchie's Avatar
frenchie
Sweeeeet I see the notch and problem solved; can you believe Ive been looking for that notch for 6 months! Thanks again
Old Sep 22, 2008 | 08:32 PM
Monk Edsel's Avatar
Monk Edsel
Wow, I didn't even know the gas cap had a tether! Mine has none. It would've saved me the cost of a new cap when I accidently knocked mine from its perch on the fuel door into apparent oblivion.
Old Apr 3, 2010 | 07:55 AM
womble's Avatar
womble
Reviving a Dead thread. Wife's uncle recently purchased a 2005 MCS Cabrio. Fuel Cap tether is missing. Have spent the last hour or so cruising the web and cannot find a part number. Wasn't planning on heading to dealership this weekend. Anyone got a part number? Source link? Thanks. tw
Old Apr 3, 2010 | 05:34 PM
MLPearson79's Avatar
MLPearson79
According to RealOEM, the P/N is 16116760043 and should run you less than $5 from the dealer, Pelican Parts, etc.
Old Apr 3, 2010 | 06:39 PM
womble's Avatar
womble
Thanks, I'll give them a try Monday.
Old Apr 8, 2010 | 07:31 AM
womble's Avatar
womble
went to dealership yesterday. They wanted to sell me an entire cap with the tether attached.
Old Apr 8, 2010 | 09:19 AM
MLPearson79
The tether is a separate part number...if they won't sell it to you I'm sure someone online will (Pelican Parts has it).
Old Apr 9, 2010 | 02:11 PM
Tom D's Avatar
Tom D
Can someone verify that the part#16116760043 is actually the tether?
When I searched on Google Product Search all the results call it a "ground cable". Thanks.
Old Apr 9, 2010 | 04:23 PM
bean's Avatar
bean
Realoem.com is your friend on such matters.
Old Apr 9, 2010 | 07:02 PM
Tom D's Avatar
Tom D
Realoem is not my friend in this instance, they also call this number a "ground strap" :(
Old Apr 9, 2010 | 10:08 PM
MLPearson79
Hm. It's in the pictures but maybe it's no longer available.
The entire cap with the tether should run around $20 though.
neezebeeze
Oct 31, 2016 12:10 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
riff42
Sep 22, 2015 03:07 PM
mini_mike237
Sep 21, 2015 08:42 AM
Grizld700
Sep 15, 2015 05:34 AM
