Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
TPS on OBD2 port
Old Sep 17, 2008 | 03:03 PM
pure13's Avatar
pure13
TPS on OBD2 port
I want to hookup Throttle Position Sensor to my Traqmate. From using Scangauge2, I know OBD2 port on R53 is providing TPS information. Anyone know which port is the TPS?
I tried using a voltmeter to detect change in current in all the OBD2 ports when I modulate the throttle, but was not successful at detecting any change. So the signal might be digital?
Thanks in advance.
Old Sep 17, 2008 | 07:05 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
I believe your're right.
http://en.wikipedia.org/wiki/OBD-II#OBD-II
Old Sep 17, 2008 | 08:59 PM
big howe's Avatar
big howe
Yes it is digital. You won't get any analog signals out of the OBDii port. The scangauge doesn't have any on-board I/O either. I have a Dashdyno, which will give you a couple of discrete outputs and analog inputs I believe, but no analog out.
Your best bet is to actually tap the wires at the TB and pull the analog signal there. I'm not any help in telling you which ones, but that is where I would look.
I am unfamiliar with the Traqmate so I am unsure of it's abilities.
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
flpat73
Nov 2, 2015 06:38 PM
micromini234
Sep 30, 2015 07:36 PM
SneedSpeed
Sep 10, 2015 07:22 AM
Sep 2, 2015 11:15 AM
