R50/53 2006 S rear brake pads...
Old Sep 16, 2008 | 09:25 AM
animalhause's Avatar
animalhause
Hello, My wife and I have posted a couple of questions regarding our Classic Mini in the past. We just bought an 06 S and I had the tires rotated yesterday and was informed that the rear pads would be due soon. I was wondering if there are any special tools that are required to do the job. I am mechanical and do a lot of my own work on the cars we have and feel confident with doing the job as long as I don't have to buy a special (expensive) tool.
Thank you,
Diego
Old Sep 16, 2008 | 11:29 AM
ddawson's Avatar
ddawson
Nope just a typical brake job. I suggest a tool to spin the rear caliper piston in to make life easy. A little PB Blaster on the screw that hold the rotor on will keep you from striping it out. A 2x4 and hammer to knock the rotor off.
I ordered the one from Harbor Freight as I had a punch of individual cubes from other cars.
I used a little anti seize on the screw and hub so next time the rotor and screw can be removed a little easier.
There is a FAQ on the front and rear brakes in the mod section.
Old Sep 16, 2008 | 12:36 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Here's the link for rear pad changing, https://www.northamericanmotoring.co...ad.php?t=43438
This is the tool you NEED to make life easier, http://www.harborfreight.com/cpi/cta...emnumber=40732
Also make sure the inside pads clips are clipped to the piston on the sides and top.
Old Sep 16, 2008 | 02:47 PM
Capt_bj's Avatar
Capt_bj
yep - that nails it....
the HF tool is not a 'must have' but you DO need to turn the piston as it is pushed in so the tool makes that easier....or, open the bleeder valve and don't fight the system, but collect a wee bit of fluid. You still need to turn and push but some like to do that with needlenose rather than buy a tool. Watch HF....the kit is on 'special' every 3 weeks for $20 and it has the adapters for just about everything that uses this (not uncommon) e-brake system
Old Sep 17, 2008 | 07:05 AM
animalhause
Hey thanks a lot gentlemen! A brand new HF just opened in town so I will go check that out today. The tire shop wanted to charge me $240 for the rears only and that was without turning the rotors. They did mic them and they're in spec and I have no pulsation when braking so I think that I will forgo the machine shop.
Old Sep 17, 2008 | 09:17 AM
ddawson's Avatar
ddawson
Remember that pads transfer material to the rotors. If you use a different pad without turning them they may squeak.
I always replace the rotor because turning just removes more metal, but that's just me being ****.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
