R50/53 Rear bumper removal?
Old Sep 15, 2008 | 03:31 PM
Bang110's Avatar
Bang110
Search didn't find what I wanted..
Ned to take the rear bumper off to replace the side marker lights with my new clear ones. The front bumper is cake and I have removed it many times.. But the rear is a virgin. How can I get it off?
Old Sep 15, 2008 | 08:27 PM
AutoXR53's Avatar
AutoXR53
Can you get at them by taking the inner fender liner out?
I will be doing the same thing shortly but w/smoked side markers instead. Can anyone else shed a little light on this if I am mistaken.
Old Sep 16, 2008 | 06:42 PM
Bang110's Avatar
Bang110
Anyone?
Old Sep 16, 2008 | 07:08 PM
MUShadd's Avatar
MUShadd
you dont need to remove the bumper. just remove the retaining screws to gain access. removing the wheel is a big help. but if you must remove the bumper, its very simple. i did it without instructions of any kind. just start removing every screw that you seen connected to the bumper.
Old Sep 16, 2008 | 07:16 PM
ToBFree's Avatar
ToBFree
I replaced mine including new wiring. It was easier to remove the wheels and the wheel wells. If you want to fight it, you can take out a few of the rear-most well plastic screws, pop out the wheel well edge, and work your fingers back in there. It'll take a short screwdriver. The more screws you remove the more you access you can gain.
Old Sep 16, 2008 | 07:28 PM
OctaneGuy's Avatar
OctaneGuy
Lift the boot lid--remove the two screws inside the rubber bumper stops, for the top. Underneath the center backup/fog light, there is a screw that holds onto a little bracket that needs to be removed.
You have to remove the arches--just pull them off--underneath is a screw that holds the bumper cover down--those are the end screws.
The cover should come off.
Richard
Old Sep 16, 2008 | 08:09 PM
Bang110's Avatar
Bang110
Thanks!
Old Sep 16, 2008 | 08:16 PM
OctaneGuy's Avatar
OctaneGuy
You might find my DIY helpful..although it shows the Cooper bumper, the attachment points are the same on the Cooper or Cooper S.
https://www.northamericanmotoring.co...341#post551341
More pix from the Sport Link Install
Richard
Thanks!
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
I_drive_slow
Aug 18, 2015 10:47 AM
skippermini
Aug 12, 2015 10:05 PM
bctf1
Aug 6, 2015 12:55 PM
