R56 Quick Sport Suspension Question
Old Sep 7, 2008 | 06:40 PM
bfrance's Avatar
bfrance
Just to confirm, the sport suspension on the '09 Cooper just adds bigger front/rear sway bars, correct?
I didn't opt for it, thinking that I could do better aftermarket for the $$$, but if it's more than just the bars, I don't want to regret not getting it!
-Ben
Old Sep 8, 2008 | 07:15 AM
Mini2na's Avatar
Mini2na
I have an '07 with sport suspension. In a discussion I've now forgotten, I think there are other components that are "beefed" up. A quick call to ALTA would get you some great information and advise.
Hands down, ALTA is the best auto parts/mod company I've ever dealt with.
Old Sep 8, 2008 | 10:17 AM
TheBigNewt's Avatar
TheBigNewt
The SS is a 2mm thicker front/rear sway bar, that's it. Comes to 18mm in the rear. Bad news is that if you thicken both the rear and front the understeer that you lose with the thicker rear bar is negated with the thicker front bar. Since the purpose of the sway bar is to reduce understeer you've basically bought nothing for $500. The springs and shocks are the same. There's reason that many companies sell thicker rear bars and noone sells a thicker front bar.
Old Sep 8, 2008 | 10:37 AM
mellowmcs's Avatar
mellowmcs
springs and shocks are the same? I'm not sure about the spring rate as it also depends on the options you get but the shocks for sport and non-sport package have 2 different part numbers. which would lead me to believe that they aren't the same.
Old Sep 8, 2008 | 10:52 AM
TheBigNewt's Avatar
TheBigNewt
They do supposedly have different part numbers, but I've yet to find one person who thinks they are different. I think the assembly line folks get a box of parts for the SS option and the stuff has different numbers on them even though some is the same. Just my .02
Old Sep 8, 2008 | 02:38 PM
mellowmcs's Avatar
mellowmcs
in my experience that's not how BMW does the part numbering. they do have master part numbers for group of parts but the individual parts in the kits (if they are the same) have the same part number.
in the e46 323i, it's easy to tell the difference between sport and non sports. sports being much stiffer. i think it's just that the mini with the runflats and fairly stiff springs makes it more difficult to tell the difference between the shocks by the butt measurement method.
Old Sep 10, 2008 | 02:42 PM
MotorMouth's Avatar
MotorMouth
argh!!!!
I can believe it got asked again - that's no problem.
What I can't believe is how people keep giving the WRONG answer.
Sports suspension changes front and rear sways, and also DOES change the springs and shocks.
Although I base this on technical knowledge, a quick ride over a bumpy road in both versions will make it obvious the springs and shocks are different.
Old Sep 10, 2008 | 09:50 PM
whoapower's Avatar
whoapower
Thanks MotorMouth.
If the information is out there, or to be had, I'd like to get some data on the factory, SS and JCW spring rates, if they are linear/progressive and the valving differences if any.
Old Oct 11, 2009 | 04:14 PM
LiL Stinker's Avatar
LiL Stinker
So do I hear y'all right, that the SS is more than just sway bars? For $500 extra I was hoping for more. Getting ready to order an 2010 MCCS.
Old Oct 14, 2009 | 09:40 PM
MotorMouth's Avatar
MotorMouth
Can't speak much louder over the internet.
Old Oct 14, 2009 | 10:27 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Your post is chock full o' mistakes. The thicker bars to NOT cancel each other out. Both the front and rear have different functions. Most companies don't produce front sway bars are because of how much of a pain they are to install. Most people don't want to tear apart the front end of their MINI just for a change that can be almost replicated by a strut bar.
Old Oct 15, 2009 | 08:23 AM
Michael Czeiszperger's Avatar
I would think the MINI site would be the definitive source:
http://www.miniusa.com/feature-sport-suspension.html
"You can also choose the Sport Suspension option, with stiffer springs and stronger anti-sway bars for even more aggressive performance. ..."
Old Oct 15, 2009 | 08:40 AM
andyroo's Avatar
andyroo
Agreed.
Although you don't want to go TOO big up front, it does serve a function.
- Andrew
Old Oct 15, 2009 | 09:49 AM
strobeyprobey's Avatar
strobeyprobey
Shocks are different for sure (they have a big label on them that says SPORT which is not on a reg suspension MINI), and by the feel of it, I believe the springs are different as well.
I have an 08 Cooper with the Sport Suspension. I love the handling of the car, a bit rough sometimes (but I have read many times once I get rid of the Run flats it will be awesome). I recommend the sport suspension!
Old Oct 15, 2009 | 10:59 AM
RJKimbell's Avatar
RJKimbell
+1!!
Old Oct 15, 2009 | 11:33 AM
wludavid's Avatar
wludavid
I ordered the Sport Suspension and 15" non-runflat tires. I have high hopes for this setup. Actually, I have high hopes for the whole car.
Old Oct 16, 2009 | 06:33 AM
strobeyprobey
Okay, so this morning I got a loaner car. I think it is an 09 Cooper (non-s), no sport suspension, 15" non-runflat tires. IT IS A DOG for handling. I jerk the wheel and the body starts rolling long before it starts turning, AWFUL AWFUL AWFUL compared to my Cooper's 16" (run flats) and sport suspension!!!!
You did the RIGHT thing getting the sport suspension! It always very easy (and relatively inexpensive) to upgrade your wheels later if they don't give you the handling you desire. :-)
Old Oct 16, 2009 | 09:10 AM
k3v1n's Avatar
k3v1n
Mine is with SS, and the ride is definitely stiffer and it handles a lot more aggressive. After two days with my MINI I was given a Cooper S 6 speed loaner without the SS and the difference was very noticeable. Like someone mentioned it handled like a dog. You can tell the spring/shocks are different because it was also a lot smoother over bumps.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
theblackfalcon
Oct 11, 2015 09:49 AM
ltjpunk7
Sep 6, 2015 07:32 AM
xpunisherx
Aug 10, 2015 10:50 PM
