R56 Aftermarket exhaust tips on stock pipe?
Old Sep 4, 2008 | 11:45 AM
zooki's Avatar
zooki
Has anyone just added different exhaust tips onto the stock tailpipes? I don't plan on replacing my exhaust system, but I want to put some angle cut tips on. Anyone done this without having to cut the pipe? Any pics? Thanks for any and all replies.
Old Sep 4, 2008 | 12:58 PM
maximus96's Avatar
maximus96
i think the tips are easily removable. you can easily replace them with JCW tips for example...
Old Sep 4, 2008 | 02:05 PM
4xAAA's Avatar
4xAAA
The tips are a little tough to remove, depending on how long they have been on. There is a small hex head screw on the underside of the tip. Loosen those, drive the MINI for a little bit, spray the TAIL PIPE with water, not the tips, then tap on the back of the tip with a rubber hammer.
Should pop off with a little help.
Old Sep 4, 2008 | 04:58 PM
sk8erguyzach's Avatar
sk8erguyzach
it works rather well did this last week worked great
Old Sep 4, 2008 | 06:56 PM
toolazyforalogin's Avatar
toolazyforalogin
Anyone know of any places to get a black exhaust tip? It's the last bit of chrome on my car. Thanks.
Old Sep 4, 2008 | 10:10 PM
sk8erguyzach
local autozone/pepboys
Old Sep 19, 2008 | 07:41 PM
toolazyforalogin
Think I can spray paint the tip black with high heat paint?
Old Sep 19, 2008 | 09:41 PM
slinger688's Avatar
slinger688
I think the high heat paint may work. On a couple of other cars, I used to paint my shiny exhaust black to give it a more sporty look. But the surface may not be as durable as chrome or stainless. Paint prep is most important else the paint will peel.
Old Sep 24, 2008 | 11:34 PM
zooki's Avatar
zooki
Okay, I found some exhaust tips that fit on the stock tailpipes without cutting or welding. They just slid right up over the tailpipe and clamped down. tell me what you think. Sorry about the dirty car!
Old Oct 1, 2008 | 03:39 AM
Noegel's Avatar
Noegel
Looks good to me!
Old Oct 1, 2008 | 07:57 AM
MiniManiac74's Avatar
MiniManiac74
Where did you get those tips at and what size are they?
Old Oct 1, 2008 | 08:46 AM
zooki's Avatar
zooki
I bought the tips from my local Autozone. They had to order them from Superior Automotive. The part number is 28-6301. They are 3 1/2" x 6"
I found the tips on Amazon also
http://www.amazon.com/Superior-28-63...2875721&sr=1-1
They just slid up on the pipe, and I used the top 2 bolt on clamps to hold them. With a little black paint on clamps, you can't tell how they are attached unless you get down at ground level and look closely. Plus I was able to slide them up far enough to not worry about burning my legs by mistake!
sevin
May 2, 2026 06:11 AM
ltjpunk7
Sep 6, 2015 07:32 AM
ASRman
Aug 13, 2015 09:33 AM
ti22fjc
Aug 9, 2015 05:49 PM
